Old 01-22-2003, 03:06 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Originally posted by Moppie
I also noted someone mentioned throwing the car in neutral to slow down.
Don't.
Change down throuh the gears as you slow down, its better for the car and gearbox, and it means your ready to move off should the light change, or something happens in frount of you requiring you to have total control of the car. (e.g. dodge to the side etc)
Is it? I always figured downshifting and shit all the time would put more strain on the tranny. Whatever though, you posted some great info
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 01-22-2003, 03:29 PM
darolh darolh is offline
Downshifting does put more strain on the tranny. It's an old way of slowing the vehicle down when brakes sucked (before we were born). The only time you "need" do it is to be ready to get on it as you exit the corner you just set up so brilliantly for. Regular boring driving doesn't require it.
I do it all the time anyway 'cause I like stirring the gearbox and listening to the motor. My bad. I also shift without the clutch sometimes just for fun to prove I can. In my old 5.0 I used to shift without the clutch all the time. It was an easy gearbox for clutchless shifting.
Old 01-22-2003, 03:36 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Doesnt this grind the gears?? or do u have to find the "sweet spot" to do this, or is there a certain RPM you can do it at? i'm not gonna try cuz i'm afraid of grinding the gears but i have heard about it. i'll just stick to the clutch method when shifting for now lol:smoker2:
Old 01-22-2003, 04:16 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Yo - I like this thread...Good info Moppie and darolh.
I often downshift too when stopping..keeping the weight of the car on the engine eases brake wear (like darolh said) and also allows for quick control with the throttle if you need it. Those of you who don't live near ice may not care, but if you try to stop and lock up your wheels on a piece of ice in neutral, you are in trouble. I love working the gears too as I downshift.. When I sit tho my throwout?? bearing (there are so many bearings I forget which one) is wearing out so I push the clutch in if I am not sitting for too long so it isn't noisy like when I sit in neutral with the clutch out.
Shifting without the clutch I think puts more strain on the synchros, but is good practice in the event you need to do it. and yeah..there is kind of a sweet spot..the key is to have the tranny and engine spinning at the 'same' speed so the gear will side in without grinding too bad (or if you are good, not at all ). I already have to double-clutch 3rd to ease on the grinding..I hope my Si tranny going in with the ZC doesn't grind
When I go into reverse, I always hit 2nd as I stop, cuz it is easier to get into than 1st (if I am still rolling a little) and does all that fnacy shit Moppie said..and it cuts WAY down on the grinding..I don't think reverse is synchroed in our trannies, so doing what moppie said helps that issue and makes your car :flash:
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 01-22-2003, 04:50 PM
No synchro on reverse and it's a straight cut gear (that's why it's so loud).
All ya gotta do there is if it doesn' go straight in reverse, lift on th eclutch a bit to get things spinning and it'll drop right in without a fight.
Old 01-23-2003, 08:18 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Putting your foot on the clutch puts pressure on the throw out bearing, which makes it go quite. Unforunatly its when its under pressure that it suffers wear.
So your actualy increasing the amount of wear and shortening whats left of its life, even though it does sound better, its actualy not.
89 clutch replace? Hard? auto89 Pick-Up 0 03-04-2010 06:18 PM
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
03 Ride Height Problem - 03 Silverado 1500 z71, 5.3L tallroach85 Silverado 2 04-03-2009 10:30 AM
Installing a clutch pedal assembly towelie Ranger | Courier 1 02-15-2009 07:18 PM
