Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-24-2005, 10:46 AM
2001Sport_Traccer 2001Sport_Traccer is offline
Re: rough idle until engine warm on cold day
Originally Posted by mblax
I have 2000 Explorer with 50K. Same issue, rough idle on cold day until engine warm. Runs fine once warm. I live in Texas. Did this last winter and just dealt. Spring, summer, and fall was fine. Winter hit and here we go again. I replaced idle air valve last week. Plunger on old valve was sticking so I was optimistic that was the problem. No luck. Still have same problem. Suggestions? Please reply.
We're in the exact same boat, then; I'm getting no error codes from the computer, just crappy performance on the first start of the day.
Fuel pump? Fuel pressure? Can't take it to a Dealer (bad word) because once there, I couldn't duplicate the problem. Any thoughts are appreciated by the world at large here, because I'm finally at a loss.
Old 01-24-2005, 11:03 AM
brokesilverado's Avatar
brokesilverado brokesilverado is offline
Re: explorer idle and temp problem
my 99 was doing the same thing i replaced the iac and the tps (throttle positioning sensor) nothing but i did check the ERG valve and the EGR valve sensor on a friends explorer and that seems to have cured the problem the erg vavle will make the enging temp rise if it is not working properly. I have yet to do it to mine yet.
Old 01-24-2005, 09:20 PM
Thanks--I'm on that tomorrow then. It's the only problem I've had since purchase, and it's driving me up the wall.
(This is from a guy that probably spent two hours over two days aiming the fog lamps correctly. Heh.)
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
Surging and temp problems wesley's mom SC/SL/SW 2 12-08-2005 04:00 PM
coolant and temp problems. benw C/K 2 08-03-2005 07:51 PM
94 explorer starting and stalling problem chevy4me Explorer | Explorer Sport Trac 3 12-18-2004 01:41 AM
94 Explorer starting and stalling problem chevy4me Camaro Discussions 4 12-15-2004 09:38 PM
