Old 12-30-2007, 05:24 PM
cass w cass w is offline
Re: Tamiya Honda RA 273 1/12
great looking ra daniel very nice detail . the shocks are a nice touch
Old 12-31-2007, 05:44 AM
SeanyG's Avatar
SeanyG SeanyG is offline
Daniel, as I said over at F1m, its just a fabulous piece of work... I need to learn your photography skills too... or a buy a better camera!
Fabulous stuff matey!
Sean
_______________________________
http://www.scalereproductions.co.uk
WIP: Ferrari F40
Old 12-31-2007, 05:50 AM
daniel_k daniel_k is offline
thanks to everyone for the nice comments !
about my photography skills ..well I don't have any :-) but luckily these pictures turned out OK, if you have problem with you pictures try to add more light or shoot outside.
daniel
-germany-
Old 12-31-2007, 05:54 AM
kanedge kanedge is offline
Great job, very neat.
Old 12-31-2007, 06:54 AM
Robi J's Avatar
Robi J Robi J is offline
Beautiful, both model and photos!
Robi
Old 12-31-2007, 07:15 AM
cinqster's Avatar
cinqster cinqster is offline
Very very nice build! I should add that I've cocked up two of these models before!
Old 03-02-2021, 02:52 PM
Ace11's Avatar
Ace11 Ace11 is offline
Daniel,
Beautiful work!
I was just going through my kit and I discovered the windscreen was cracked in half!
Could you advise me on how to make a vacuform windscreen?
Thanks,
Carter
Old 03-02-2021, 04:56 PM
Hahahah...wow a reply after 13 years, that must be a record. Thanks for bringing this thread up and reminding me of this nice forum.
The window wasn't vacuformed. I just used some really tthin clear sheet and used the original screen as a template. I also used a hairdyer to soften the sheet a bit and make it conform to the old screen. I used rivets to finally attach the screen.
Here a progress picture. But I really think you nee to attach ist with rivets becasue the screen will spring back into it'S old shape
Daniel
Cologne/Germany
https://www.facebook.com/scale.details
Old 03-03-2021, 11:01 AM
Ace11's Avatar
Daniel,
Thanks for the pic. I am beginning to see how I might do this. Do you recall what type of clear plastic you used--the source? I have some various kinds in my materials box, and it looks like experimenting is in order before I subject the kit windscreen to the heat.
Did the plastic settle over the windscreen very rapidly?
Perhaps extra-small straight pins might make good rivets.
After viewing the pics on line, the heat-formed windscreen looks more prototypical.
vb,
Carter
Old 03-03-2021, 11:20 AM
Hi,
if I remeber it was actually some evergreen clear sheet. Don't know the size but maybe I still have some and can measure it.
At first I made a template from tape as you would do with CF decals and traced that on the sheet, attached the cut out sheet over the original screen and used heat to make it conform. BUT that doesn't work too good so that's why some strong bond to the body is needed, like rivets. Otherwise the screen will jump to it's flat shape...
Daniel
Cologne/Germany
Old 03-03-2021, 11:21 AM
P.S. ...actually the process is pretty easy. Just make sure you fit the screen, drill the holes in the body for the rivets before doing any painting. This way you can attach the new screen to the body with tape and drill holes through the body and sheet for a perfect fit.
Daniel
Cologne/Germany
