Old 11-29-2007, 06:01 PM
UncleBob UncleBob is offline
AF -Advisor
Re: 01 honda civic timing belt replaced no start
Originally Posted by forcefan97
Hondas are pretty good cars , wish they had timing chains. Well the shop found some worn out and damaged valves & some other stuff , so the head is getting rebuilt. Lesson to be learned , change the timing belt every 90/ 100k .
I wouldn't say that personally. For example the honda 2.4L has a chain, and they've been failing a decent amount.
Belts are simple, all you have to do is watch for oil leaks under the timing cover and replace them at the recommended intervals. Its pretty easy IMO
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 11-29-2007, 07:31 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Hello
Sounds like you lucked out with only a valve job! What do the cylinders look like? Is there a ridge on the top of the cylinder? I'm betting that there isn't a ridge and the cylinders still have the factory crosshatching marks in them.
How was it doing on oil before the belt broke? How many miles were on that belt?
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 11-30-2007, 02:04 PM
forcefan97 forcefan97 is offline
Originally Posted by LeSabre97mint
Hello
Regards
Dan
Hey Dan,
Are you talking about the tops of the pistons ? If so , i notice some little dent marks from the valves.If you are talking about the cylinder walls , i havent looked at that closely.The oil was fine , didnt notice to much oil consumption. The t. belt had 260 k miles on it .
Old 11-30-2007, 05:11 PM
AF -Advisor
thats gotta be a new world record
Old 12-01-2007, 11:31 PM
Yah !!!!!!!
It should of been done @ 90/105 k.Well lesson to be learned. Got the head back from the shop w/ replaced intake & exhaust valves.Got done tonight and fired up the car. It ran !!!!!!!!! So dont wait til 260k to do the 1st timing belt . Do it at every 90/105 k miles . Also change the h2o pump and tensioner to .
forcefan97
Old 12-02-2007, 12:47 PM
AF -Advisor
Yah !!!!!!!
forcefan97
You could shorten that up a bit "follow the maintenance suggestions in the manual"
There's plenty other things that if ignored will cause traumatic failures.
Most honda timing belts break between 140-160K, that I've done anyway. Did 3 of them just last couple weeks.
