| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
#16
Re: Water/Methanol Injection
Best regards, Dan |
#17
I have a question, what if i wanted a way to switch the W/M on and off and say when it was on for track days or what have you DSMlink would recognize it and load a different map that had higher boost and a fuel map for the W/M. would that be possible?
1995 GSX 2Gb bumper Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5 /Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs ![]() Wish list: CAMS |
#18
What type of inputs do you have with the DSMLink to switch between maps?
If you were using the VC-25 controller from Labonte MotorSports, it has an injection dissable. You pull a wire to ground with a toggle switch to dissable the injection for when you are stageing the car for a drag race or running a differnt map. Dan |
#19
Kinda what i want to do is when i flip that switch on i want DSMlink to automatically swith to my "race map" for the W/M. In all honesty i dont know the inputs for DSMlink. someone els on here could answer that better than I can
#20
Looking at the User Guide for the DSMLink, it looks like software that allows you to download maps for WOT into the stock engine computer. If that is the case you will need some type of aftermarket engine controller to do the map swapping that you want (AEM)
A simpler solution might be to tune your engine with the DSMLink for the water injection and use a fail safe that activates a solenoid to limit your boost pressure to wastegate pressure. Best regards, Dan |
#21
another thing, you would only need an fmic if you plan on switching the meth on and off. people can run constant meth 24/7 and not have an intercooler at all, the meth causes the air temps to get progressively cooler with more boost. In this case, the fmic would only slow down airflow. Also with a setup like that, you never have to worry about heatsoak.
#22
Yea but if you had a FMIC also it would cool the air down to a resonable temp them the water/meth would make it even colder. Plus you would have to have a big ass bottle to keep from refilling it everyday.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#23
If your main fuel is gasoline, you still need an intercooler. You aren't injecting enough meth, it's still 95% gasoline. Only running 100% meth only (as your main fuel) can you get away without an IC.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#24
Running out of meth during a run is something that I have been worried about, since my only protection comes from a warning LED and the CEL coming on in the presence of knock. But I'm not sure if that would give me enough time to get out of the throttle before something bad happens.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
#25
Labonte MotorSports sells an Injection Fail Safe unit (IFS-10)
It is designed to monitor your injection flow and if it drops below a set point it outputs a 12v signal. You could use the 12v to toggle a map in like the AEM or they have a boost bypass solenoid that will limit you to wastegate boost pressure. Best regards, Dan |
#26
Now that I think about it, I can't see a way to do it with DSMlink... It only works on outputs, no inputs. My bad.
