#16
Re: Noobie Needs Help
Holy crap! no joke, about a week ago i was driving to school and my clutch decided to not disenguage until halfway to the floor! then it had to go all the way to the floor! it really is a conpiracy! Anyway, I filled the fluid and expected to find a leaking cylander but no go, after an hour of searching and pumping the clutch nothing, and still i havent had any issues, very very strange.
oh, and welcome to the forums srtike.
1992 Mitsu 3000gt sl 5sp - High flow filter - Pioneer head, dual 10's - H4 headlight conversion - Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod - LED "Snake Eyes" - Lightweight Crank Pulley -More to come- ![]() Your 3000GT is the 5095th out of 6964 . Only 41exactly identical Bloody Knuckles from Changing Fuel Filter Crew Member #1 |
#17
I refuse to walk quietly through life, only to arrive safely at Death's doorstep. "When the rich wage war, it's the poor who die" ![]() |
#18
yeah I hope you get my luck also! haha, it was pretty odd though. well if your not having any clutch slipping then your clutch is fine, its prob a leak, but if your having trouble finding a leak then try the gravity bleeding technique. (ask stealthee or seach on here or on 3si.org) im thinking then your problem will be solved
#19
Suhweet. Someone else has experienced the gnomes. People dont know what to think if they see myself or LUSTFUL talking about the gnomes on 3si.
Just wanted to (hopefully) bring this issue to a close. Got one of our customers to bleed my system to see if there was any air in the lines. He said that the slave cylinder had a very small amount of fluid behind the rubber boot. According to him it doesn't look like there is a leak, or if there is it's really small. And now the friction point and everything seems to be where it should, and the shifts are smooth and without gear grinding. So hopefully this is the last time I will have this issue for a while. Thanks to all for your help and advice in getting this fixed!
#21
if this time it isn't fixed,just change the slave cylinder.... i can almost guarantee that is where your problem is at. and no type of fluid should be by there anyways, and also it doesn't matter if you have a small or a big leak, a leak is a leak and any type of leak when it comes to braking systems, or clutch lines(since they both use the same type of fluid) a simple leak can be very critical and will effect any system... my slave cylinder went out a while back and all the symptoms you have stated are the exact ones i went through... changed the slave cylinder and my problems where gone.... and on 3/s's it is very common to get a leak from the slave cylinder
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
#22
#23
The slave cylinder is easier to change than the master. There shouldn't be any fluid at all behind to boot, if there was it's time to change it.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
#24
#25
You actually wouldnt even have to replace it, you can just rebuild it (just change out the seals) a new one will cost about $40 for a slave and $70 for a master, so not too pricey but you can get a rebuild kit for about $5.00
pm jason bet if you need that, he can usually get you a good price.
#26
#27
You should post some pictures up. And last time I bought a slave it was $20 from Autozone, the rebuild kit was $15.
#28
Your car is a 96, right? I think the "snake eyes" mod can only be done on 1st gen, since they have the popup lights. There are a few good posts here on how to do it. The faq's have good tips on mods, it really depends on what you're looking to do. If u wanna mod looks, and you want the snake eyes, try to find a conversion kit ( I think they make them...?) for 1st gen lights. Other than that, new rims is all I would recomend, since I think that the 3s body styling is already cooler than any kit youcan buy for it. As for performance, Exhaust, headers, test pipe, Intake and gutting the precats seem to be the cheapest and most poplar first mods on most of the cars on this forum.
'97 3000GT SL -Short Ram Intake -Test Pipe -Custom Exhaust -17" Infinity Rims -Infinity Kappa Component Sound System -Kenwood Double Din Headunit |
#29
#30
