Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-30-2007, 10:46 AM
poormillionaire2 poormillionaire2 is offline
Re: Security Light
Originally Posted by wrightz28
column stays, but I would do a lot of studying up on disabling air bags.
Got that covered, disconnect battery and pull the fuse from the fuse/relay box. www.shbox.com has some great write-ups with pics and stuff. But I think everyone knows about that place.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 10-31-2007, 04:21 PM
Re: Security Light
Ok, so I checked the purple/white wires from the ignition lock and they sent signal back fine. I heard that something is making a clicking sound when I try to start it. Its not the starter, but something either from under the column or around the firewall. What would be making that clicking sound but not engaging the starter? I may just have to replace the cylinder lock, I don't know yet. All that alarm wiring was a PITA to get around also.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 11-02-2007, 06:58 PM
Re: Security Light
Anyone know what that clicking is?
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 11-03-2007, 12:04 AM
5046adam 5046adam is offline
Re: Security Light
the clicking is your starter relay tripping its killing your starter and injecters. just do what i said earlier i bought the plug bypass from ecklers camaro but i dont need it it's in a drawer right now. i could of saved 38 bucks if i knew about this at the time. trust me its easy
Old 11-03-2007, 12:17 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Security Light
If it's coming from inside the cabin, it could be your BCM. If your bettery is ever too low to crank the car over, and you try to start it, you'll hear this clicking from inside.. that's the BCM. In case you're not sure what the BCM would sound like, in that situation you can hear it.
Just another thought.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 11-03-2007, 01:36 PM
Re: Security Light
But isn't the BCM/TDM under the passenger-side dash? The clicking I am hearing sounds like it is coming from the the middle-to-driver's side. Possibly somehwere around the firewall.
Well, actually, there are two clicks. One I found to be coming from the fuse panel that is in the engine bay. But the other is hard to locate.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 11-03-2007, 01:38 PM
Re: Security Light
I would, but I don't know if it would work with my new alarm, since it kills the motor if the alarm goes off. I looked at the wiring, and a lot of wires are plugged into a central alarm module under the dash. Its hard as hell to locate anything down there anymore.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
