| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
#16
Re: Stroker, High reving, spooling...
No I haven't looked into that yet. But I'm going to look into that. How much work is involved in this? If there's custom fab involved... it's not happening.
I'm looking to (after the build + tune) be at about 300-400hp. 350 would be perfect... however I know I'm still always going to be pushing for more power even after that. The motor itself I want to be able to handle 550hp no problem. Again, used as DD and some track use. Would not be driven hard all the time.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
#17
Check out 2gnt. All the info is on there.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#18
I'm not sure what is entailed, but someone on here told me that the mounts are pretty similar. (Both engines line up the same way) I would imagine other than the engine and tranny, you would need an ECU and a engine wiring harness. MAYBE a cabin harness, or perhaps some rewiring of the exsisting harness.
1991 GSX 2.3 Stroker |
#19
100mm Eagle crank Manley H beam "turbo tuff" rods Wiesco Pistons (+.020") +some other needed parts(ie. hardware)
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
#20
#21
I went with a stroker because I will probably never see the track and plan on having it as my DD for awhile. It just feels good to know that I have plenty of headroom for bigger turbos. I just can't wait to finally get 'er in there.
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
#22
I'm a 2.0 man all the way. The other thing with a 2.0 is that when you get a mid sized turbo (like a 50 trim to support 350-400 hp) it wont be spooling much during norml low RPM driving. Thats one thing that drives me nuts about the 16g, it seems its spooled all the time and when I am just bumming around I would rather not be using the gas needed to do that. I know a guy that threw a 35R on his car and got IIRC like 2-3 mpg better because he wasnt spooling during normal driving.
#23
#24
Whats this about a 4g64 swap? That would be sooo much work. My 4g64 sits on the opposite side of the engine bay than the 420a. It would basically be like swapping in a 4g63 which is no small task. Which you might as well swap in a 4g63t.
Unless you are talking about swapping in a late model eclipse 4g64 or a galant 4g64 since they sit on the same side of the engine bay as a 420a, but I've never heard of anyone doing this.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
#25
420a's can be stroked too vanilla. Besides, a 2.4 isnt a "stroker" motor as it has the same stroke as it comes from the factory. A stroker is an engine with a lengthened stroke.
I would also like to point out that where this is some great 4g63 info, the 420a may have a different bore/stroke and the stroker 420a is a 2.2 IIRC so much of this may be irrelevant. |
#26
#27
The 2.4 motor is not the eclipse 2.4. It comes from a different car, its not a direct swap, it does require some fabrication but I think it would be worth it.
http://forums.2gnt.com/dcboard.php?a...2252&mode=full http://forums.2gnt.com/dcboard.php?a...1958&mode=full http://www.2gnt.com/index.php?d=2.4L...20by%20Skrilla
#28
Too much fab is involved. I haven't welded or done anything of that sort ever. And I don't feel like paying someone who has no idea to do it. Does seem interesting though.
#29
Just when I thought I knew everything, I learn something new. Interesting. I'm going to read up on this just for the fun of it.
#30
Could you stoke the 2.4 out? Or is the stroke in it already pretty long in order to get the extra dissplacement?
