Old 10-12-2007, 07:31 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Problems Problems ...
hmm is it possible the compression gauge was leaking? but id check timing belt as well... good luck
Old 10-12-2007, 08:49 AM
stnapycnaf stnapycnaf is offline
Thanks for all of the suggestions.
The timing belt is not broken, loose, but not broken.
And the compression tester is brand new ... I bought it 30 minutes before I ran the tests.
I have access to a timing light, I just don't know exactly what I'm doing with it
91 CRX HF
D16A6 Swap
Old 10-12-2007, 08:54 AM
Kind of a Big Deal
i would make sure the timing belt hasnt slipped a tooth. put the engine at TDC anf make sure the cam is lined up proper
Old 10-12-2007, 03:28 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Well you need to put that timing gun away for now cause that only adjusts ignition timing on a RUNNING motor.
All you need is a 17mm socket and a ratchet.
What you need to do is turn the crank (counterclockwise) until the white mark on the pulley is aligned with the tick mark on the lower timing cover. That's TDC. Then you should check your cam gear to see where its at. The UP mark should be pointing up, and if you have a D16a6 a separate tick mark should be aligned with a mark on the head. It should be all in a manual.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 10-13-2007, 01:58 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
yeah, you saying the belt is loose, I'm leaning toward skipped tooth, and all your problems w/ the battery touching the intake are coincidental.
Old 10-13-2007, 10:24 AM
Alright well as soon as my dad gets back with the jack, I can get to the crank pulley.
Would a couple teeth really kill my compression like that?
I'm going to school to be a Honda Tech right now, but I just started about 5 weeks ago. It would've been, I guess, a little more convenient if this happened 8 months from now.
91 CRX HF
D16A6 Swap
Old 10-13-2007, 10:26 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yes. If say, your cam is not in time with the pistons, then when you go to do a compression check the valves could be slightly open when the piston compresses..essentially killing any chance of making pressure.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-13-2007, 10:44 AM
So why are there such variances across the the cylinders?
Are some of them closer to being properly timed than the others [the 90 psi vs the 32psi]?
91 CRX HF
D16A6 Swap
Old 10-13-2007, 11:12 AM
Kind of a Big Deal
yep, the valves are at differant spots being open.... they dont all open the same amount at the same time
Old 10-13-2007, 11:31 AM
that's the reason I told you to do a compression check, now, if you really wanna find out if you're leaking past the valves or the rings, put a teaspoon of oil in each cylinder before you do the compression check... if the numbers don't go up, then it's the valves.
(God I love being a hillbilly.. with limited access to tools and parts... but only sometimes.. )
Old 10-13-2007, 12:25 PM
I'm sitting here looking at my crank pulley and I see no tick marks ... or a white mark for that matter ... I can barely see my lower timing cover. Am I missing something?
Also, do I need to remove the A/C and Alternator pulley to reach the crank pulley? Because thats how it looks to me
91 CRX HF
D16A6 Swap
Old 10-13-2007, 01:20 PM
No need to remove any pulleys, your just checking timing. Is your upper timing cover already off? If not you need to take the valve cover off to see the cam gear. I guess you didn't want to download the manuals so I did the work for you.
Old 10-13-2007, 08:33 PM
dude ... you rock
thanks A LOT
91 CRX HF
D16A6 Swap
Old 10-13-2007, 10:47 PM
Umm ... what if there's no white mark?
91 CRX HF
D16A6 Swap
Old 10-13-2007, 11:18 PM
Kind of a Big Deal
its probably worn off... im not really a d series guy... but there should be 3 slashes and then some space between them and maybe 2 more? it should be one of the two slashes... not near the 3 close together.. sry if im not makin any sence.. sox are on and ive been drinking since 8..
