Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-07-2007, 04:42 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: please help, boost problems
Originally Posted by mydelsol
Ok but what do you think about my logger showing .02 for the o2 volts when at WOT? This website says it should be in the upper 25% http://www.pocketlogger.com/index.ph...am=o2&type=dsm
Should I get a new sensor?
This could be a problem unrelated. Usually a bad O2 Sensor will throw a CEL but not always. The symptoms you are describing do not sound like an O2 sensor problem to me. But what the problem with your O2 sensor is, I don't know. I'm sure someone else here may be able to enlighten you.
There are two O2 sensors, one on the O2 Housing off the turbo and the other behind the cat. Are you logging from the O2 sensor in the front or back?
I don't put much faith in the stock O2 sensors. The only way to get real good readings is to use a wideband O2 sensor.
1991 GSX 2.3 Stroker
Old 09-07-2007, 11:53 PM
mydelsol mydelsol is offline
I'm not sure which sensor I am reading from. I thought the 1g didn't have the second sensor, only the 2g's did. I will have to look into that. Thanks a lot for the help.
1993 del sol s
1990 Eagle Talon Tsi Awd
Old 09-08-2007, 07:19 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
did you boost leak test it beyond the psi your car is rated at? if so you should see the wastegate start moving. if it doesnt, or if it somehow got damaged, it will let all boost get by. this wouldnt cause your idle to do that though. a high idle at start is usually a vaccuum leak, possibly electrical. o2 could have affected this
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 09-08-2007, 11:51 AM
When I tested it the first time I had a better compressor and I tested it until the wastegate opened, which was around 10psi. Yeah I think I'm going to try and get a new o2 sensor that goes in the o2 housing. Any suggestions on where to buy a good one from? Thanks
1993 del sol s
