| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
#16
Re: CEL for emissions
Are you trying to get rid of the second o2 altogether? As far as I know you cant eliminate the sensor completely.
I dont think it matters which way the resister and capacitor are.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#17
and here is what i came up with: ![]() ![]() ![]() had it on the car for about 3 weeks (dont drive the car that often) and the cel came on the other day... as explained earlier... WTF? any ideas on how to get the ECU to think my Rear o2 is their? i need to maybe ask kevin... or Brian... bet they would know... u think? |
#18
And that doesn't work? I would watch those resisters to make sure they aren't getting to hot. The problem I see is that that type of setup only gives the ecu a constant reading so the computer picks that up as an error bc the signal isin't changing. With the sensor connected the signal varies but the resister and capacitor slow the reading down so that the cel isin't triggered for no cat.
#19
I wouldn't recommend T-ing off the sensor, the WB needs to be in the exhaust stream. There is a link on page 1 of how mine is set up. You might just need to weld another bung in your exhaust for the WB.
#21
DSM ECUs don't really care what the rear O2 absolute voltage is, AFAIK. All the ECU is looking for is that the rear sensor signal is not cycling like the front one is. Back in the day many people had good success just tying the sensor up somewhere where it won't start a fire. This is where wrapping it in foil came from, to protect the car from the heat. The sensor will provide a low, flat voltage to the ECU. This is usually enough to keep it happy. The anti-foulers only limit the sensors exposure to the exhaust gas, to slow down the cycling. These have been reported to work pretty well for people on the EVO forums, worth a shot.
With more modern cars, the ECUs are a little smarter. They force the AFR to change at certain intervals to ensure the sensors respond as expected. There are also ways to force the readiness tests to "pass," but this gets more complicated.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#22
AFAIK??? so your telling me to take the sencor out of the pipe and to wrap it in foil? and that will take care of my cel? *i was hoping you would stop buy and drop some knowlege keven!*
#23
The only way to find out if it will work on your car is to try it.
#24
point taken... ok! thanks buddy! how would you suggest I tie it up?
#25
Zip tie that bitch up there
#26
This is the wierdest thing I have ever heard of. I will have to give it a try.
1991 GSX 2.3 Stroker |
#27
will i have to drive another 500 miles to reset the cel? because it didnt turn off right away... i should know this, but you know... might as well ask to just make sure...
#28
so you wired the sensor back up and wrapped it in foil? It will take a few days to go off.
#29
Did you try removing the battery leads for 10 seconds and reconnecting them? This should reset the computer.
