Old 01-26-2004, 04:04 PM
454Casull 454Casull is offline
Re: Perfect spark plug?
Yep, I decided TiB2 would be better as an electrode material. Last I heard it resisted oxidation under 700C very well.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 01-26-2004, 06:19 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Originally Posted by 454Casull
Assuming an infinitely powerful ignition distribution system, what gap would you use? What electrode positioning would you use (extended, surface-fire, Halo-type, standard)? What electrode material would you use? What electrode plating would you use, if any? What insulation would you use? What shell material would you use?
Also, do you believe in that HotWires stuff?
Link
I would probably use a surface-fire plug /w a gap of 0.1-0.5", an electrode material of ELKONITE 2050C, iridium plating (because I don't know the inertness of the material), and probably a Ceralloy 418 insulator.
ELKONITE 2050C - 0.0297 ohm-mm˛/m electrical resistivity, 330W/m-K thermal conductivity, up to 3400C melting point.
Ceralloy 418 - low thermal expansion, high dielectric constant, 250W/m-K thermal conductivity
Id probably use the one that lit the mix with the least voltage and caused less hits on the KS. any more is waste.
Old 01-27-2004, 12:08 AM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
any of you here who might have cut back the ground electrode on there J gap spark plug notice more power, better responce, or better gas mileage?
Old 01-28-2004, 11:17 AM
SaabJohan SaabJohan is offline
Re: Re: Perfect spark plug?
Use one of the platinum group metals instead. Has lower electrical resistivity and are one of the most inert metals at higher temps. They have also excellent strength at high temperatures, for exemple iridum based superalloys are one of the most heat resistant alloys, can be used at temps above 2000 degC.
Their price do however beat almost anything else on the market.
Old 01-28-2004, 04:53 PM
Re: Re: Re: Perfect spark plug?
I'll agree that oxidation of TiB2 is present at very high temperatures, but high strength at high temperatures is what TiB2 does well. Besides, with the high resistance of the spark cabling, and the REALLY high resistance of the air gap, a few more ohms of resistance won't matter. TiB2 is nominally conductive anyway.
Old 01-30-2004, 07:10 PM
Re: Re: Re: Re: Perfect spark plug?
The platinum metals do already have a high strength in high temperatures so there is really no improvement. Ceramics does also break before their ultimate strength (but they are good at compressive stress). But I don't think the strength is so important (it's more about oxidation resistance). The module of elasticity is also about the same for both materials.
Old 02-17-2004, 01:17 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Perhaps this will spark some more discussion:
railplugs
http://www.netl.doe.gov/scng/project.../are41334.html
http://www4.ncsu.edu:8030/~mfhabel/e497/railplug.html
Sounds like a nifty way to light off a lean charge, if they get 'em
tuned well enough. I'm not so sure that they make sense for near-
stoich applications.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 02-17-2004, 04:07 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
What would kick ass, is if combustion worked like it does in Diesel engines. There would be no spark plugs, just compression.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Having 3.5L spark plugs in a 2.7L engine. Benjamin_2002 Intrepid 1 02-28-2011 05:19 PM
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
spark plug analysis keilerstag Cutlass Series 1 06-29-2009 08:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
Spark Plugs + Spark Plug wires ricodemus Engineering/ Technical 4 02-27-2002 12:23 PM
