| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
The techinque of heel-toe is used to downshift while simultaneously braking. If you drive a manual on a road course you'll suck if you don't do it well. In essence, your using the clutch, brake, and accelerator all at once but only with two feet. Usually, the right toe is used to brake and the right heel is used on the accelerator. It's pretty tricky and it takes a lot of practice to be good at.
Here's a good description: http://www.turnfast.com/tech_driving..._heeltoe.lasso Veetec - The ideal pedal kit is one that has a high-friction surface on the brake and clutch and a smooth surface on the accelerator. That way you can reposition your heel on the accelerator but your toe won't ever slip off the brake (very important!) If you don't like the height, you can shim it up with just about anything - just make damn sure that it's on there tight and won't come flying off and sticking under the brake pedal. Mugen makes a good kit but it's very expensive (of course) ![]() You can do much better by buying cheaper mfg's individual pieces from different looking sets. For instance this: ![]() plus this: ![]() would probably be great. One more thing - make sure your seat position is good and pull that seatbelt in [b]tight[/i] as you won't have a foot to brace you in the corner. I highly reccomend that you start practising on straight (and empty) stretches of road. Going a constant speed in 3rd gear, pick a landmark at the side of the road ahead of you, then brake hard, heel-toe down, and floor it. The object of the game is to get as close as you can to the landmark before braking, and to have sucessfully downshifted and back on the gas the moment you pass the landmark. Once you get comfortable with this, try a curve or two (but make sure to give yourself runout room!) (all pics above from http://www.shopresponse.com/pedals.html )
#17
OMG, is that really you Fritz?
Are you back in Pasadena, or still up north? PM me your email when you get a chance, we can catch up on things. Good to see you back on here though!Sorry to stray off topic everyone.
Silver '00 Civic EJ6 Coupe PureHonda original member since Feb. 2000 D-series revolution For pics of my baby, click here! All rights reserved... All BITERS served! "The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket." i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift hessemer69 on AIM |
#18
Why are people talking about drag racing when the topic is heel-toe? I dont think you really need to adjust them or get slippery cheap aftermarket pedals. Stick with the rubber unless you want to get those hot-ass mugen's. My meathod actually is different from "heel-toe". Its more like left and right side of foot. You can cange the way its done depending on your cars pedal set up, just as long as you can do the same thing, touch the acc. and brake at the same time. Just thought I'd share this idea. P.S., people who drive with proper rev-matching downshifts make the ride so much nicer for the passanger. My friends make me lose my lunch.
#19
1989 s13 Fastback Tein HE coil-overs sr20det swapped! JIC Magic Front and Rear Strut Bars Slotted and Cross-drilled Rotors S/S Brake Lines Pivot Lazy eye controller Blitz LM Intake Blitz D1 Spec Turbo Timer Soon to come: Sard 550cc Injectors Blitz Nur Spec Exhaust Blitz Down pipe HKS FMIC http://www.driftmonkey.com (Part Owner) |
