| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#16
Re: Cluster lights don't work. '98 RS
Dont rig up something so you dont have to trace the problem, you will regret it later. Go ahead and fix the problem.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#17
If the fuses are good, and it's just on the dash, a wire was cut or damaged somewhere.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
#18
'98 Contuor SE, 2.5 V6 Auto Silver '08 Altima 2.5S, Auto Super Black |
#19
If you have power at the dimmer control the current should go straight to the cluster and HVAC lights. I would pull your cluster out and check the plugs in the dash with a volt meter or test light and see which ones cut on with the lights and go from there. If you have power at the plug it has to be in the cluster itself.
#20
One problem more, I can't pull the cluster out. I took the outer trim around the cluster. I took the four screws off that hold the cluster but now i can't find where the plugs are at! I can't disconnect the fucking thing cause its caught!
How many plugs are supposed to be plugged in?
#21
There three sets of connectors. They slide right out, I just have to pull the cluster straight out, saw another one at the junk yard without the cluster. I'm not gonna destroy anything when i pull out am i? should the battery be connected or disconnected. I just got a new dimmer switch and it didn't work. Its a wire or connector issue.
#22
Take the 4 screws out the cluster and it will pull straight out. You dont have to disconnect the battery since you will need it connected to test the plugs.
#23
Ok, so i guess all the plugs are supposed to be hot (running power.) Here goes nothing.......
#24
Ok, so i i'm getting power at the switch and from it....so why the hell do i not see the little ligth bulb icon on the dimmer turn on? Should'n that at least be on?
#25
I dont believe thats suppose to light up, I dont believe mine does either.
#26
So here is the break down:
1) The back of the cluster had some areas where the solder contacts had a black dried liquid. Almost like acid. 2) I was getting power to only about a fifth of the total number of connectors. (Not sure how many and which ondes were supposed to be good. 3) Since i could not dismantle the whole panel i took the easy way out and just pulled to power at the switch to feed a 6" neon light. Just screwed it to the roof of the cluster. Sorry fellas, just could not find the problem.
#27
PANSY!!!!! You will be shunned!!
#28
I exposed all the wiring so that i could follow all the bundles. I still didn't find any bad connections, or cut wires. I followed them from the back of the lighting control all the way to the cluster. All the wires were good, must be hundreds of feet of wire! I tore the whole thing up and still had no success.
