Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-29-2007, 03:32 AM
Silvia GT-R Silvia GT-R is offline
Re: ca18det - sr20de
Originally Posted by assad_l
silvia gtr - getting a ka in aus: no chance lol. ive never seen one in aus let alone heard of one lol.
awdsr20 - so fuel lines and fuel pump will need upgrading if i was to put the sr20de in tha ca18det? but wouldnt the fuel pump already be big enough because the ca18det is turboed so shouldnt it be big eneough to compensate for an extra 200cc??
Look into the nissan Frunteer truck it is all in there.
But it's cool just thinking of cheep swaps.
Cause we were stuck with that motor here in the US.
Old 07-29-2007, 10:10 PM
naruto's Avatar
naruto naruto is offline
Banned
$2,500 for an N/A SR20!!!! That seems like a lot of money. I don't know much about this engine you're on about, but have you considered an SR20VE?
148kw @ rear wheels, this engine would have to have BIG cams, high compression, bigger injectors etc etc.
As i said i don't know much about this engine so if it has a standard ECU with this engine your in luck. But as the mods I've i listed above you would not be able to run the engine with a standard S13/14/15 ECU, you would most likely need a re-map or go after-market.
I think you should just upgrade your fuel pump. I'm not sure how much power these would flow up to but i don't think it would be a lot, it would probably be maxing out at 148kw atw. Also it's old now so just upgrade it.
As for the Auto-Manual conversion i also don't know exactly what you'd need, the only things i can list would be Gearbox(not sure from what model SR20), Heavy Duty clutch, clutch pedal assembly(not sure whats needed as im not sure if the silvia's are hydraulic clutch)
Also if this conversion does get completed be sure to take it easy! In you're last thread i said you'd be a tool on the roads with a high powered vehicle and you already are a tool and the cars not even high powered(your N13).
If i think of anything more I'll be sure to post. Good luck wit the conversion
Old 07-30-2007, 05:31 AM
assad_l's Avatar
assad_l assad_l is offline
Send a message via MSN to assad_l
it was 2500 for a worked n/a sr20..
Assad..
starting 180sx project soon
http://www.youtube.com/watch?v=aGRodKEfeZ4 <<<CHECK IT LOLL
Old 07-30-2007, 05:54 AM
naruto's Avatar
Banned
That's what i said. How much are you buying the 180 for?
Old 07-30-2007, 06:20 AM
assad_l's Avatar
i dunno man currently im getting 550 a week aud, ive got 1000 in my savings, sooo dont no wat im doing atm..
Assad..
Old 07-30-2007, 09:06 AM
naruto's Avatar
Banned
If you really want a 180SX or S13 Silvia i think you should just wait till you find a clean example that's already got an SR20DE and is manual. I think $2,500 for a N/A engine is too much, understandable if it was a worked SR16/20VE but a DE that's too much, that's the price of DET engine.
Your plan to do this swap is a total waste of money IMHO.
CAR - $6,000 - 10,000
ENGINE - $2,500
WIRING LOOM - $???
ECU(Re-MAP or After market) - $700 - $2,000
EXHAUST - $500 - $1,500(Including cheap brand extractors)
GEARBOX - $???
PARTS FOR MANUAL CONVERSION - $???
ENGINE MOUNTS - $???(I don't think they'd be expensive though)
RADIATOR(Auto model has the gearbox fluid running through it too) - $200 - $700
I just did an estimate with the prices i have listed and guessed the ones that don't have a price and it came to a total of $13,900, $14,100 - 200 to get the after market ECU tuned.
Remember these prices do not include labor.
You've still got a fair bit to save before you can buy the car so by the time you've saved about $10,000 you should be able to find a 180/Silvia for $6,000 - $9,000. Just search websites, news papers, car performance magazines etc.
Old 07-30-2007, 09:07 AM
naruto's Avatar
Banned
What state you live in mate?
Old 07-31-2007, 04:33 AM
assad_l's Avatar
nsw, aus, i might just buy an s13, then few years down the track throw a sr20det vvt in it...
Assad..
Old 08-29-2007, 12:26 AM
naruto's Avatar
Banned
HAHAHAHA. I just saw your thread on PGA (I'm a member too), make up your mind!
IMHO don't do it. You'll probably run into lots of problems, not to mention gearboxes, once you start making big power they are going to break like tooth picks.
Originally Posted by assad11
i used to until someone threw bricks at it and it got written off
I thought someone smashed into it while it was parked?
Just buy a 180SX with an SR20DE in it and start with that, they're not hard to find in NSW. Besides RWD > FWD
Old 10-03-2007, 11:19 AM
adamgtx adamgtx is offline
OMFG...
1. ill do what i want.
2. everyone knows that imports in nz are cheaper then everywhere else.
3. i must have told everyone here about 5083747856487364784 times that i live in aus and am only on my pervisional liscense so i am not alowed to drive a turboed car.
4. ive told everyone NO im not going to wait the 2 years im going to be an impatient spoil little shit and do the swap.
5. i was asking for help and tips and bs not ur fu*%ing opinions.
6. im not looking for alot of power i want around 120kw from the sr20de then when i get off my pervisional liscence i do plan to turbo the engine and get alot more power out of it.
thanks....
your very rude for a man needing help
that said
ca18det> ser20de anyday anyday
Old 11-07-2007, 03:01 PM
Turbo711 Turbo711 is offline
Not allowed to drive a turbo car? Put a VQ35 in!
1990 Fastback, putting together the chassis...
Old 11-09-2007, 02:05 PM
626 Luxe 626 Luxe is offline
Send a message via AIM to 626 Luxe
VQ's are so heavy compared to a sr...
