Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-28-2007, 07:39 PM
steviek's Avatar
steviek steviek is offline
Re: wideband questions
for the wideband?
I spliced it off the backlight for my boost gauge. Which is wired straight up to positive and negative terminals on the ecu.
It was an easy target because when I took off my afc it was right there and exposed so I was like perfect unsolder one wire resolder a new one
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 06-28-2007, 11:56 PM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
that sounds like a good idea thanks
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 06-29-2007, 09:11 AM
kjewer1 kjewer1 is offline
AF - Advisor
I've always taken power for miscellaneous interior gadgets from the cigarette lighter circuit. It's easy to tap into, already fused for 10 amps, etc. As long as you don't actually use the cigarette lighter of course...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-29-2007, 07:36 PM
a good idea as well i have so much stuff to do this weekend i dont know if ill get around to the wideband especially now that i smashed my windshield and have to get that fixed. I also have to install and areomotive FPR try to fix my idle etc etc
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 06-30-2007, 10:06 PM
well as it turn out the wideband came early so i put it in today. i got everything soldered up and installed but my gauge hooked up to the analog output is reading 8.6 at idle while my narrowband on my turbo timer reads 14.7 what could be the problem. could it be my calibration i followed the directions as best i could could it be something else?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 07-01-2007, 12:29 AM
steviek's Avatar
wait you have a narrowband and a wideband? Don't trust the narrowband at all. What part is logging the 8.6 is it the dsmlink or the actual gauge. If it is the dsmlink its probably some kind of software error. Like How i chose the wrong wideband input
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 07-01-2007, 01:21 PM
my wideband controler has two analog outputs a simulated narrowband output which is designed to go with my gauge and a much wider analog output which is spliced into my ecu. But the gauge should still get accurate readings from 9-17 AFR the second analog output is designed for readings from 7.5-22.5 AFR. Yes i still have a narrowband with my TT but theres no way my AFR is 8.6 at idle
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 07-01-2007, 01:23 PM
steviek's Avatar
what wideband are you using?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 07-01-2007, 03:16 PM
Innovate LC-1 wideband controller if you look at the link at the beginning of this thread thats the one im using except i also got their DB gauge with my kit so its all designed to go together
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 07-01-2007, 04:23 PM
well i just plugged in dsmlink to see what value it was getting and dsmlink was logging 15.4-16 afr at idle while my gauge was still off as well. Maybe i have to program the wideband and set the value its seeing at idle as 14.7 with the logging software? I assumed it would automatically figure out the afr based on the free air calibration
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 07-01-2007, 08:19 PM
AF - Advisor
Sounds like the display is set for another type of fuel, probably methanol.
Kevin Jewer
Old 07-01-2007, 11:54 PM
even if im getting two actually three diffferent readings one from my gauge one from my ecu and one from my narrowband?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 07-02-2007, 08:24 AM
AF - Advisor
The WBO2 unit may only be sending the lambda value to the display, and the display has to display it in the desired AFR unit. I can't recall if my techedge unit programs the AFR fuel type in the unit itself or in the display, but both can be programmed with a laptop. Either way, this is something to take up with the manufacturer of the product IMO.
Kevin Jewer
Old 07-02-2007, 09:42 PM
did you have the same wideband as me kevin? if so where did you ground your wires?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 07-03-2007, 12:00 AM
AF - Advisor
If I did I would have handed you all your answers on a silver platter, because that's how I roll. Unfortunately I have been running the Techedge unit for the last 4-5 years (www.wbo2.com). I don't know why it's not more popular than it is, depsite being the first supported by DSMlink, it's badass.
My unit is grounded to some bolts under the center console, since I have it mounted under my passenger seat.
Kevin Jewer
