Old 11-12-2007, 09:58 PM
KyMDLR's Avatar
KyMDLR KyMDLR is offline
Re: Honda Cbr1100xx Blackbird
an orange sharpie marker works great.
Old 11-13-2007, 01:44 PM
Ole_L Ole_L is offline
Use Tamiya clear orange X-26 for the turn lights. Put a piece of Bare Metal Foil or silver paint on the back of the light.
Old 11-13-2007, 02:23 PM
ketje's Avatar
ketje ketje is offline
Hey Ole,
do you use a brush or an airbrush for this?
Old 11-13-2007, 03:11 PM
I airbrush it as it will look much better. It's a fairly thick paint, so thinning it a bit is recommended, but you can airbrush unthinned. I paint on the outside of the part, but have seen Tamiya recommend you paint from the inside of the clear part.
Old 11-16-2007, 12:09 PM
ketje's Avatar
Honda Cbr1100xx Blackbird update
A little update
Sprayed one of the exhausts alclad polished aluminium. Now it's time to put on some carbon.
Swing arm sprayed alclad, chainprotector and decals fitted
Old 11-16-2007, 02:39 PM
ALEX GAROLI's Avatar
ALEX GAROLI ALEX GAROLI is offline
What did you use as grille in the side air intakes?, or the kit comes like that? because it looks really good.
Old 11-17-2007, 12:45 AM
ketje's Avatar
It's the mesh from the kit.
Old 11-20-2007, 01:50 PM
ketje's Avatar
little update
I've been working on the exhausts and did some CF. I also used the tamiya weathering kit for the first time.
Still needs to be clear coated.
Comments !!
Old 11-21-2007, 12:40 AM
sportracer02's Avatar
Re: little update
Originally Posted by ketje
Comments !!
what else can I say but : GREAT !!!!!!!!!!!!!!
Clean CF-work, nice wheatering, the little springs ... absolutely convincing
Micha
Old 11-22-2007, 07:06 AM
joelwideqvist joelwideqvist is offline
I agree, looks perfect! Can you describe how you made, and mounted, the fasteners for the springs as I have never tried this detailing part myself.
/Joel
Old 11-22-2007, 09:06 AM
Murray Kish Murray Kish is offline
Getting Old...
Looking great. Each piece looks like a model on it's own!
Very nice....
Murray
Old 11-22-2007, 10:28 AM
ketje's Avatar
/Joel
Hey Joel,
about the fasteners. I took some copper wire ( 0.35mm) and bended them with a round mouth grip (don't know if this is English) . Then I fitted them with cyano glue.
Old 11-23-2007, 03:42 AM
Ok. A follow up then, did you fit the second "hook" with the spring attached or did you put them at a meassured distance and then attach the spring? My worry is to get the spring to stay in place.
/Joel
Old 11-23-2007, 07:29 AM
ketje's Avatar
/Joel
Hey Joel,
I first put the second hook at a meassured distance and than after the glue had cured I positioned the springs to have a look.
The benefit of the springs is that they actually work like springs. Keep in mind to use enough cyano to put on the hooks. You can also use a bit extra cyano on both sides of the hooks to create seams .
Old 11-25-2007, 02:25 PM
ketje's Avatar
again a little update
Yesterday I had some time to work on the model with next result
I also bought some Alclad clear colours and I love it.
Judge yourself.
