Old 10-26-2002, 11:47 PM
Fireinthesky28's Avatar
Fireinthesky28 Fireinthesky28 is offline
Send a message via AIM to Fireinthesky28
yeah, dude...enhanced oxygen does in fact help combustion, thus we have turbo. HOWEVER, pure oxygen is highly flammable. The friction caused by rubbing your hand against your shirt will make enough heat to cause combustion in a pure O2 environment. You need outside gasses, (Nitrogen, Carbon Dioxide, et al.) to bring down these combustive properties.
This could go places, however, I would be interested to see it as an alternative to all common forced induction systems. Isn't how they made the blues brothers car, so it could drive underwater?
So the biblical scholars mis-translated the Hebrew word for "young woman" into the Greek word for "virgin," which was a pretty easy mistake to make, since there is only a subtle difference in the spelling. But back then it was the "virgin" that caught people's attention. It's not every day a virgin conceives and bears a son. So you keep that for a couple of hundred years, and the nexy thing you know, you have the Roman Catholic church.
-Snatch
Old 10-27-2002, 10:38 AM
1 fast POS 1 fast POS is offline
Once again it is being stated that pure oxygen is highly flamable. This is NOT the case. No fuel, no fire. Pure oxygen is a very dangerous material and is a fire hazard but only because it makes other things burn, not because it combusts. As ivymike1031 had previously stated, aluminum burns quite nice in a pure O2 environment. I wouldn't doubt this, however it is testimony to my statement. Aluminum is the fuel and oxygen is the oxidizer, you do need both. ivymike1031 hit it on the nose when he said that oxygen won't react with itself, but it will with almost everything else. Fireinthesky28 I am in agreement with you in part. The outside gasses like nitrogen and carbon dioxide don't really stabalize oxygen's combustive properties as they due reduce our atmosphere's oxidization properties. Oxidization is obviously the key to combustion, so basically these other gasses that dilude our atmosphere to a mere 21% oxygen, keep the oxygen from reacting with everything it comes in contact with. Anyways, I am probably not qualified to give a chemistry lesson, so I will leave it at this. If you want to dump pure oxygen into your engine I suggest settling for a nitrous oxide kit, they have already done the work to make sure that it is safe in your engine. I did all of this homework for you 8 years ago when I was installing a liquid oxygen tank in a 16V Jetta GLI. Lucky for me I did my homework before I road tested.
resistance to the turbo is futile
Old 10-28-2002, 07:59 AM
higgimonster's Avatar
higgimonster higgimonster is offline
just on an anal/technicality point. In the real world no matter how you use pure O2 there will always ba a fuel. whether it be the sweater you rub your hand against or the bottle you store it in or the dust particles in the air (not sure if they count though).
Promoter of the one line signature.
Old 10-28-2002, 08:47 AM
point taken....
Old 10-29-2002, 01:20 AM
sciguyjim sciguyjim is offline
As a chemist, I have used high pressure pure oxygen. There are special procedures and fittings and gaskets needed to use it safely. And, the dust IS important. Before putting the piping together, you have to try to wipe out all dust particles before opening up the high pressure O2 or the dust can burst into flame on contact. If there's a trace of oil in the piping, it can explode when the O2 is released. I know of a case similar to this where this happened and the user was killed.
Old 10-29-2002, 10:54 AM
I drink liquid oxygen for breakfast instead of coffee. I think that it makes me run faster and jump higher.
Take the chemist's advise (sciguyjim), and live to start another thread .
P0410 Secondary Air Injection System shaundavis108 TrailBlazer | Trailblazer EXT 2 03-29-2010 07:36 PM
Classic mustang to 5.0 fuel injection novi Performance 7 09-05-2009 03:05 AM
Pure Pwnage? Pure Idiot! FireBball972 COMPLETELY off-topic 9 07-06-2004 02:42 PM
Central injection vs. cylinder injection Crimhead '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 02-04-2004 09:17 AM
