#16
Re: Evo vs. Viper
303whp stock internal KA-T 94 Acura NSX Best E.T. 13.559 Best Trap speed 107.62 mph |
#17
Re: Evo vs. Viper
Thanks 209. Greg sent me a PM aleady. Unfotunately I'm tied up both Saturday and Sunday. Good luck though. Post some pics and video if you can!
#18
Re: Evo vs. Viper
The 35R should not ever be taken to 35psi. That is way past charted impeller speeds and efficiency regions.
I have seen the 35R make as much as 633whp. I personally would go past 27psi if I were trying for 600whp, just from looking at the map. The GT4202 on the other hand could do 35psi easily. In fact, that is optimal boost level for maximum power. With supporting VE mods, that is where it will have the potential to make 900whp, maybe a tad over. The 94mm, it should also stay at around 27psi to make maximum power. Of course, there is that exceptional dyno that shows each turbo making more than what I posted.. I like to not max my turbos, and stay on the efficiency islands.
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
#19
Re: Evo vs. Viper
Thats what I said.
It's All About The FINNESSe! X 1993 MR2 Turbo X New Project - 1997 Toyota Supra TT Limited Edition.
#20
Re: Evo vs. Viper
I thought you were going with some HKS cams steiner? Last time I remember talking with you, you were looking into a 264/272 set up. So, decide to drop that and opt for something else?
#21
Re: Evo vs. Viper
#22
Re: Evo vs. Viper
I've recently been reading about some of these 42R's pumping out more than 50psi for 1000whp on a 4G63 but it seems like most are running between 35psi and 40psi depending on the supporting mods. What are the limits of the efficiency range on that thing?
Tanabe 70mm downpipe, RRE Rally Cat, RS*R ExMag exhaust, K&N filter, JDM MR BOV, Hallman MBC, HKS 264in/272ex cams, Acme cam gears, Nisei lower intercooler pipe, OEM 16G IX turbo, WORKS 30% STS, Kartboy shifter base and underhood bushings, Kartboy shift knob & Hotchkis 24mm rear sway bar and various tunes by Andy at Speed Element. A set of KW Variant 3 coilovers are sitting in my kitchen right now slowly destroying my marriage but they're going in on the 2nd - along with Tein camber plates. Mods in the pipeline are JAM no-tick lifters, GM 3 port boost solenoid, EvoGreen turbo and an AMS intercooler. |
#23
Re: Evo vs. Viper
People do it and I will not disagree with it making power. But given the compressor maps, that is a very substantial overspeed. NTM, a lot of those guys are running extremely high octane fuel like VP import, so the IAT increases caused by traveling that far out of the efficiency islands can be negated by the octane rating and quick-burn technology combustion chambers allowing low timing advance. Pressure will increase flow, no doubt about that. But I would rather not tax such a pricey piece of equipment that is doing something it was not designed to do.
35psi is exactly what you should run to near 1000whp. Given it isn't charted to make 1000whp, that would be the "best of the worst" area to be. You would need crazy good VE to even near 1000whp at 35psi even on a 2.3L stroked 4G63... Thank Mitsubishi for an already outstanding head design. For 1000whp and above, the GT4788-R is probably your next stop. I would buy this turbo if I planned on making over 800whp. But thats me. The GT45R will touch 1000whp if you think you are gonna stop right when you make 1000whp. Who stops? All of these turbos come with the same AR options for turbine side, so there is really no reason to buy one over the other for spool unless you think that inertia related boost threshold increase of like... nothing, matters..
#24
Re: Evo vs. Viper
2002 Firehawk (M6) http://www.youtube.com/watch?v=6XKnrV7c_Bs F13 cam (230/232, .595/.585, 112+4 LSA) | PRC Dual Valve Springs | LS2 Timing Chain | Ported LS6 oil pump | Pacesetter LT's | TSP catted y-pipe | Flowtech cutout | LS6 intake | SLP lid | SLP cat-back | Bilstein suspension | Tuned by Mayhem Motorsports 1998 Pontiac Trans Am (A4) - SOLD slp lid, pacesetter lts, ory, flowtech cutout, fuddle 3400 stall, B&M tranny cooler |
#25
Re: Evo vs. Viper
Re: Evo vs. Viper
Just wanted to bump this with some pics of the car on the new KW3 coilovers. Man what a difference! I'm still dialing everything in (it takes a while with the 2 way adjustable setups I'm told) but at 75% it performs like the car did at 95% on the stock suspension...
#27
Re: Evo vs. Viper
rusted rotors on such a beauty?
In a thread titled "What Made You Feel Old?" on Retrojunk.com, Quote:
#28
Re: Evo vs. Viper
he probably just washed the car, and didnt use the brakes yet, it's wat happens wen metal and water mix
yup, here i am |
#29
Re: Evo vs. Viper
{runs out to look at car}
Yeah they look good now. I think vectorspecialist nailed it. I had finished washing the car 30 seconds before I snapped that pic. |
#30
Re: Evo vs. Viper
yea had the same problem with a pic of my stealth, just started it went into reverse, down the driveway, hit the brake, and went back up, all good now
yup, here i am |
