Old 05-16-2007, 11:05 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Strokers
[quote=GreyGoose006]
Originally Posted by kevinthenerd
in "stock" form, it will rev past 9K.
with "proper" parts and building, you can get a 6" stroke engine to rev to 9K+. The point is....how money you got? How much power do you want to make?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 05-16-2007, 11:16 PM
kevinthenerd kevinthenerd is offline
Re: Strokers
[quote=UncleBob]
That would result in a mean piston of 9000 feet per minute. I'm going to go out on a limb and say that I don't think anyone has EVER done that. I can't imagine what the cam would look like to sustain that either. The cams would be open for so long that you'd need a second engine just to spin it fast enough to start. F1 motors spin to 5200 ft/min, and NASCAR engines spin to 5600 ft/min. Quarter mile dragsters range from 5500 to 8000 ft/min.
Let's try that again.
Old 05-16-2007, 11:24 PM
AF -Advisor
Re: Strokers
is that so? Must be impossible then. Heh
Old 05-17-2007, 07:29 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Strokers
Originally Posted by thatchevyguy
im going to weld up the spider gears for pisitraction.
you're going to weld up the diff for a 50/50 torque split?
good luck with the tight low-speed turns. squealing and skipping inside tyre.
Seatbelts Saved My Life
Old 05-17-2007, 08:17 AM
thatchevyguy's Avatar
thatchevyguy thatchevyguy is offline
Re: Strokers
I'm only going in a straight line
Old 05-17-2007, 08:38 AM
Re: Strokers
you have to turn around at the end of the track.
you will have to make turns. and when you do, you'll get the inside tyres squealing and skipping.
Old 05-17-2007, 09:27 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Strokers
I've been told by a few people that it is better to build a stroker motor out of a 350 2-bolt main than it is out of a 350 4- bolt main because the 4- bolt main is made for pulling which is low rpm, i would like a few other opinions
I would like to echo what Kevin pointed out... the order of strength in the SBC world goes like this: 2-bolt, then 4-bolt, then (strongest) 2-bolt modified for 4 bolts. The 2-bolt blocks have more meat down south.
Dragging people kicking and screaming into the enlightenment.
Old 05-17-2007, 02:14 PM
Re: Strokers
pine valley raceway has a long sweeping turn around, and i wont be going any faster then 10 or 15 mph, thats exactly what i did to my 85 el camino (for the strip) and i have had no problems
Old 05-17-2007, 07:25 PM
Re: Strokers
so what? People weld their diffs for drag racing all the time. They know they won't be turning, and they don't care about ever turning efficiently. A welded diff is often stronger than a more expensive limited slip anyway, and the welded diff doesn't have to start slipping before the load is re-transferred.
I like turning, but I'm not complaining about the drag guys. They're having fun, and a lot of them are good at what they do.
Old 05-17-2007, 08:06 PM
GreyGoose006 GreyGoose006 is offline
Re: Strokers
it will bind, but with large sidewall drag tires, it should be ok
they have been doing it for years and years with no problems
Old 05-17-2007, 10:49 PM
Re: Strokers
i'm just not a fan of welding a diff. seems a very crude solution to me.
Old 05-17-2007, 10:57 PM
AF -Advisor
Re: Strokers
having the strongest rear end possible isn't crude. "simple" answers are sometimes teh best, as long as you know the limitations that go with it.
Drag race only car won't care one bit about the limitations though, so there's no real disadvantages
Old 05-17-2007, 11:12 PM
Re: Strokers
fair enough it's the best soltuion for various reasons.
can't you buy a solid "diff" unit?
Old 05-18-2007, 05:29 AM
Re: Strokers
yeah. probably. but why? if you are on a budget, this works just as well and is a lot cheaper
Old 05-31-2007, 08:45 PM
talkmoooore talkmoooore is offline
Re: Strokers
I agree. I did the same for my stroker motor.
_____________________
Mylene
Ron Jeremy Radiators - Download the Custom Aluminum Radiators by Ron Jeremy Racy Products
