Old 05-13-2007, 11:32 PM
G_Bo32 G_Bo32 is offline
Re: Headlight Mod
I need to get a passenger glass headlight so i can finish mine
1994 3000GT SL
60k Miles
Work in Progress
Old 05-13-2007, 11:44 PM
dhrubio's Avatar
dhrubio dhrubio is offline
Send a message via AIM to dhrubio
Re: Headlight Mod
looks good 2extreme, i dont know if you ever saw 'disrupter's sig on 3si but ur headlight mod definitely looks like its on its way to it, im really close to taking off that green plastic cover inside like you did, and then leaving a strip of green paint on the outside like disrupter has on his sig, i noticed u dont have ur outsides painted tho, or even if u like what im talking about lol anyways it came out really good!
Old 05-15-2007, 03:30 PM
Atomicornpuffs's Avatar
Atomicornpuffs Atomicornpuffs is offline
Re: Headlight Mod
Hi. This is my first post so bear with me. I have a 98' 3000GT SL and I've been looking at that beautiful job you did on your headlights on your 94'. I have a few questions about my driver's side headlight, that it looks to have either a clearcoat mishap when being created, or otherwise the seal was not very good when the "Lexan" piece was sealed onto the main body of the headlight assembly. I was wondering first off, what this could have possibly been to create this "bubble of air" or whatever it was to discolor my headlight, as well as to how hard it would be and what would need to be done to get roughly the look of X2Xtreme360's headlights. I wanted to do something like this before I even bought the car, so I was just wondering how you'd have approach this for a 98' GT. Thanks for any help in this process. Here's some pictures of the problem I was talking about as well as a pic of my GT. Hope someone can help.
Old 05-15-2007, 05:04 PM
AutostradaVR4 AutostradaVR4 is offline
Re: Headlight Mod
thats weird. is it rough to the touch? looks like it was sanded or something.
anyways, yea, like stealthee said, try and get your hands on some 94 headlights.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 05-15-2007, 07:21 PM
Re: Headlight Mod
I don't believe it's been sanded. I went out there today to go look at it really close and was just wondering about it. So apparent if I don't have the 94' headlights, it's not created with the glass seal as opposed to the 95' and newer which have the "Lexan Plastic" I presume. And from what I know of the 95' and newer, the paint is right on the inner part of the plastic seal, unless I'm mistaken. If so, could it have been that the layer of paint was not put on right for it's first coat? As well as my other question is, not more of whether or not it'd be easier to do the headlight mod if I had the 94' lights, but my question is, is it possible to do it with a 98' 3000GT's lights, and if so, does anyone know the steps to doing this. Thank you to anyone who can give me advice on this question of mine.
-Atomicornpuffs
Old 05-15-2007, 09:30 PM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
Re: Headlight Mod
Thats a common happening on all the lexan headlights. Its a clearcoat on the outside.
http://jagvr4.8m.com/hrestore.htm
Follow that link to clean that up. As for the robo mod, its not going to be anywhere near easy with the lexans. As stated the paint is directly on the inside of the lexan. If you remove the lexan cover you will see where its painted. It would tons and tons and tons of work to get it perfect to be able to pull off the robo mod. Get ahold of some 94 lights.... Like BUY MINE.
Old 05-16-2007, 01:59 AM
Re: Headlight Mod
thanks for the input on Lexan lights. So if you were to do it for the lexan headlights, you take off the sealed plastic piece and inside you find the paint. So if you were to actually want to pull off the "robo" look you'd need to sand down the paint on there? could there be some sort of solvent that would just destroy the paint yet leave the plastic Lexan fine? I'm just wondering if there's a different way to approaching the situation. I'm an aspiring *hopeful* Mechanical Engineer in college and I love looking at shedding new light on a situation. haha, light, headlights...all right it was bad, but you get my point of whether or not you could use a solvent rather then spending hours sanding the inside of the plastic. I'll see if I can do anything with the 98' lights before I go and spend money on 94' lights. but we'll see what happens. ;-)
Old 05-16-2007, 07:25 AM
Stealthee's Avatar
Re: Headlight Mod
No way any kind of solvent isnt going to destroy the lexan. This is what you do. Buy a set of 94s to pull off the robo look. As soon as they are done, pop the lexans out, pop the glass ones in, and sell the lexans. BAM its done.
Old 05-16-2007, 09:09 AM
Zeiss's Avatar
Zeiss Zeiss is offline
Re: Headlight Mod
I did this long ago, and still love how it looks.
Bye V8...
Old 05-16-2007, 02:31 PM
Re: Headlight Mod
ugh...:drool:
robo lights and victory hood...so nice...
Formerly BlinkRA182
Old 05-19-2007, 05:17 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
Re: Headlight Mod
hey..i have a quick question..first off let me say that is an excellent step by step write up on how to do this.but one question...when you are going to put the glass back on for re assembly..do you have to apply a new sealant or do you use what was there and it will melt itself back together while in the oven??? thanks
Old 05-19-2007, 06:17 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Headlight Mod
no, you do NOT have to apply new sealant. you can re-use what is there. just heat it back in the oven to get the sealant soft, then put the glass back on, and put those metal clips back on too!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Stealthee's Avatar
Re: Headlight Mod
I used the old sealant again.
Old 05-20-2007, 03:14 PM
X2Xtreme360 X2Xtreme360 is offline
Re: Headlight Mod
I used a combo of old sealant and a tiny bit of new sealant to seal off the areas that looked open. Other than that, old sealant.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 05-27-2007, 06:10 PM
Re: Headlight Mod
thanks for the link stealthee for getting the apparently clearcoat problem addressed. That link though I have a question about if anyone knows. The guy is saying to wet sand using 1000 grit sandpaper and continuing up to 2000 grit sandpaper, by any chance could you use a product like Nu Finish Scratch Remover to take car of this problem of stripping away the clear coat? I'm just wondering because with sandpaper this fine, it I would think would act just the same way as the microscopic ways of Nu Finish, so just if anyone has any input on that. also, does anyone have any experience with using Nu Finish car polish? is it actually as good as people say? thanks.
-Atomicornpuffs
98' Mitsubishi 3000GT SL
