| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#16
Re: '86 Trans Am - Numerous problems
The in tank pumps aren't expensive, just a pain to drop the tank to change them. |
#22
ive got the old fuel pump off, and i tried to install the new one but the push rod isnt in the retracted position. how do i get it in the retracted position? i took off the distributer cap and cranked the ignition numerous times but the pushrod wont move. what do i do?
knowing my luck when im done installing the new fuel pump, that wouldnt have been the problem and it was the accelerator pump. thats just how optimistic i am about my damn car right now. |
#23
turn the engine over by hand. The pump's pushrod rides on an ecentric built into the camshaft, you need to turn the engine slowly and push in on the push rod at the same time to fnd the "retracted" position.
#24
im screwed. yesterday when my dad was working on it when i was at work he tried tapping the push rod in farther, and now we cant get it out. weve been tapping it in farther to see if it will go in to where its supposed to be after cranking the engine but we cant get it all the way. i really want to get it out but the only way to get the push rod to move backwards is to actually start the engine for a second after weve tapped it up as far as it can go. i have a feeling weve really screwed ourselves by forcing it up, but that is really my dad's mistake because hes the one that seized it in the first place. any suggestions on how to get the push rod out or any suggestions on what we should be doing?
i have a good feeling that the pushrod is getting bent from us tapping on it and since we cant get it out, i thought that maybe i could drill into the rod and thread something into it so i could at least get it out, then just buy a new pushrod. im really getting sick of this car, nothing is going right with it. and with my luck i will finally get the fuel pump fixed and that wasnt the problem. i cant wait to get my motorcycle. Last edited by Fit4Demolition; 05-20-2007 at 01:20 PM. |
#27
Keep turning the engine over and see if it will dislodge. Then replace it.
Once the rod is free and replaced, coat it with some heavy grease before pushing it up. If it still won't stay up, there is a threaded bolt hole on the front of the engine in line with the rod. It may or may not have an accessory mounted to it but it will have a bolt in it. Use a longer bolt and FINGER tighten it while holding the rod up. The bolt will contact the rod and hold it up. Make sure you replace the original bolt when you have the pump installed Also, make sure thet the previous owner didn't stick a bolt in there that was/is too long and has trapped the pushrod. The pushrod shouldn't stay up on its own like you describe. |
#28
Make sure the accessory bolt I mentioned above isn't too long and pinching the pushrod. If it is, that could have been your fuel delivery problem all along. |
#30
