Go Back   Automotive Forums Car Chat > Dodge > SRT4 > SRT4 Problem Diagnosis
Old 04-30-2007, 08:30 AM
fast_driving2007 fast_driving2007 is offline
Re: I Need Some Quick Help...
i just have a intake and a bov...and their gapped at like .045
Old 04-30-2007, 11:56 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
How much boost are you running?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 04-30-2007, 06:21 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Originally Posted by endlessheart666
Know though, that doesn't work in every situation. Mine had the tps problem and no matter what you would do with the wires nothing would change the rpms.
Have you been gapping the plugs correctly when you have been changing them? What are you gapped at? Should be around .035 or less since I'm uncertain of your mods.
It has worked everytime I've stated it on the srtforums.com site. It worked for me as well. Also, I wouldn't recomend a gap of .035 if you don't know what all he's running including what plugs. There was a TSB for a plug change so the gap amount also changed.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-30-2007, 06:45 PM
i have the ngk sparkplugs...and im running like 16psi
Old 05-01-2007, 07:09 AM
Ok, that helps somewhat. Which NKG plugs you running?
Pioneer 4900mp
Orion C63 Coax rear
Old 05-01-2007, 09:38 AM
iridiums
Old 05-02-2007, 07:06 AM
OK that's probably one of your problems. Good ole copper cores seem to work the best. That's what they call for from the factory. Back when I had bucking problems and such I had put a set of platnums in it. After changing back to copper core and get MOPAR performance plug wires seemed to help a lot. Then later I found it was the MAS harness.
Pioneer 4900mp
Orion C63 Coax rear
Old 05-02-2007, 08:18 AM
Turbodog97's Avatar
Just a Neon
Mas?
05 Srt4
97 Mx-5
Old 05-03-2007, 07:17 AM
OOPS! I meant the TPS sensor or throttle position sensor harness and not the MAS.
Pioneer 4900mp
Orion C63 Coax rear
Old 05-04-2007, 07:58 PM
well i got it back from the dealer finally and it was the fuel pump causing this.....
Old 05-18-2007, 11:41 PM
UnderEstimate Me's Avatar
UnderEstimate Me UnderEstimate Me is offline
Yeah, never ever use platinum plugs on a turbocharged car.
The guys at autozone always used to insist giving them to me, and I pretty much had to pull their teeth to get them to order me the set I wanted.
2005 Neon
Stage 1 PCM l K&N CAI l Mopar rice plate l 3'' TBE l Spring mod l PB shift knob l Mopar strut bars F&R l ACR sways l Tokico Shocks/ Tein Springs l Ricey wing removal l JMB Catch Can l QW FMIC l Autometer WB l Diablosport Predator
Old 05-19-2007, 09:56 AM
Well those guys at the Zone only know what the computer or "Bible" tells them. Outside of that they normally barely function in society.
Pioneer 4900mp
Orion C63 Coax rear
