Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-12-2007, 08:28 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: whats better abt the 6bolt motor then the 7bolt?
The first post scottsee made should have been more than enough to satisfy your questions.
Read first then ask questions after if you still have them. We are not here to regurgitate information to you, we are here to show you where to find it.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-14-2007, 04:48 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
dsmtuners.com is good also their upgrade guide is super simple and helps ypu find parts too
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 04-14-2007, 12:53 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I believe I already posted that once.
95 Talon TSI AWD
97 Eclipse GST
Old 04-14-2007, 01:09 PM
steviek's Avatar
steviek steviek is offline
Everyone always misses the number one advantage of 6 bolts over 7 bolts.. its so simple too. 6 bolts are far superior because they weigh less by saving weight by reducing the number of bolts on the crankshaft... they probably weigh 50-60% of a tenth of percent LESS
Think about it!~
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 04-14-2007, 09:33 PM
2of9 2of9 is offline
because when chuck norris looked at a piece of iron, the iron feared for its life and it turned into the 6-bolt block. thats why its better...
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 04-14-2007, 11:47 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Man...that Chuck Norris is very handy...I could sure use him around here...hahaha
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 04-15-2007, 12:35 AM
WaFFeL WaFFeL is offline
Here ya go, since nobody can decide the differences between the 6 and 7 bolt engines I decided to lay it out to the best of my knowledge
1) The 6-bolt and the 7-bolt are called this is due to the number of bolts that the flywheel/crank requires.
2) The 6-bolt has stronger connecting rods than the 7-bolt.
3) 6-bolt engines have a larger throttle body, intake runners and intake manifold than the 7-bolt.
4) The last thing is that the 6-bolts have an adjustable cam angle sensor which can be used to give some more timing to the ignition.
5) Also, the 6-bolt engines are quite beefier than the 7-bolt ones.
These are all the differences to the best of my knowledge...feel free to correct me
