Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-13-2007, 06:59 AM
rprough's Avatar
rprough rprough is offline
Re: Diagnostic Code
High Performance Cam Lobes? What is this refering to? Seperate cam lobes physically? Also, is a 2az-fe a non-interfering emgine type?
Old 04-13-2007, 08:43 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Diagnostic Code
Sorry, I was thinking of another type of variable cam system. The VVT system modifies the cam timing, not the cam lobes used.
http://www.billzilla.org/vvtvtec.htm
The concept of lower oil pressure preventing a higher-performance cam configuration still holds.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-14-2007, 06:14 AM
rprough's Avatar
Re: Diagnostic Code
I now understand how the oil pressure affects the cam timing. Is this system how higher performance is attained or just a way to protect the engine at higher speeds?
Old 04-14-2007, 01:05 PM
Brian R.'s Avatar
Resident Chemist
Re: Diagnostic Code
Advanced cam timing shifts the torque curve upward to higher rpms, which makes the engine more powerful at higher rpms. The cost of this is less drivability and torque at lower rpms. A test for correct operation of the VVT system is to activate it at idle. The engine should idle rough or die because the high-rpm cam timing is not suitable for low-rpm use.
Conversely, a cam timing/lobe profile that is good for mileage and low-rpm torque is not optimum for high-rpm performance - the engine doesn't breath as well.
With the VVT system, you have a good low-rpm cam profile/timing. The system is changed at some rpm (4000 or so) to give a more aggressive cam timing, increasing the high-rpm torque/performance.
When low oil pressure prevents the cam timing from changing as it's supposed to, it is not adequate to protect the engine. The only way to really protect the engine is to shut it down. Keeping the engine from creating maximum hp at low oil pressure is just a by-product of the VVT system.
Old 04-14-2007, 03:59 PM
rprough's Avatar
Re: Diagnostic Code
How is the VVT acctivated at idle?
Old 04-14-2007, 04:30 PM
Brian R.'s Avatar
Resident Chemist
Re: Diagnostic Code
Just lie to the computer - See the 3rd page of the description in the TSB above
Old 04-14-2007, 10:27 PM
rprough's Avatar
Re: Diagnostic Code
Is it possible to do this without the meter?
Old 04-14-2007, 10:54 PM
Brian R.'s Avatar
Resident Chemist
Re: Diagnostic Code
I don't know. It might be a CAN function that is enabled in the more modern diagnostic instruments...
Old 04-15-2007, 07:48 AM
rprough's Avatar
Re: Diagnostic Code
Hmmm Time to research this for myself. I think I will look through the shop manual and see If I can not scare something up.
