Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-17-2007, 09:46 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: 1st gen vr4 vs. 91 integra b16 vtec & 06 wrx
Well your LT1 must be well modded to be hitting 12's. A VR4 that is a 2nd gen on up or has a free boost mod can run mid 13 to upper 13's. It has 320hp and 305lb/ft tq. 0-60 in about 4.8 seconds.
Old 03-17-2007, 11:21 PM
formulaD formulaD is offline
it has lot of stuff , heads cams ,ramair,exhaust,to much to list, but gets bad gas mpg and's not the most reliable car,thats why i was interested in a 1st gen vr4 for a daily driver cause there pretty cheap, whats the specs on a first gen
  #18
Old 03-17-2007, 11:32 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
If you can drive here's how it'll play out. You all launch, you'll be in the lead off the bat, the 'teg should fall behind right away, the wrx (assuming it's not STI) should fall back to your back wheels right away. You'll gain a car length at about 80, and keep gaining more and more.
Easy win.
Once again, thats if you can drive.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
  #19
Old 03-18-2007, 01:18 PM
AutostradaVR4 AutostradaVR4 is offline
vr-4's are not good daily drivers. They may cost less to buy than a gen 2, but maintenence costs are just as much if not more.
its not that theyre unreliable cars...its just that not many people can work on them and parts are expensive.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
  #20
Old 03-18-2007, 03:48 PM
youngcaradvc youngcaradvc is offline
If you want a good daily driver then just get a Honda Civic, its reliable, gets great mpg, and they are cheap. Just keep your Firebird for the weekends or an occasional drive.
  #21
Old 03-18-2007, 07:56 PM
Hotshot8792 Hotshot8792 is offline
first gens are pretty much identical to 2nd gens. Depending on the year of the 1st gen, you could end up with a cast crankshaft instead of a forged and an 18 spline transmission instead of a 25 spline transmission. As far as power goes, they are identical except for the fact there is a small nipple inside the stock boost solenoid that limits the boost at 9 PSI instead of 11 PSI which are 2nd gen levels. Removing that nipple is known as the free boost mod. That pulls you up from the 1st gen factory rating of 300 hp to the 2nd gen rating of 320 hp.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
  #22
Old 03-18-2007, 07:58 PM
Originally Posted by Duck_3000
And well to make a long story short. The same week I got my 3kgt I was the fastest out of all of them. Four months ago my friend slapped on a Turbo on his hatchback Civic. He pulls pretty hard, but I can still take him. So much for talking crap.
And a month ago, a kid slaps a T04E turbo on his sentra, blows his engine and catches the entire engine bay on fire. Burned everything. Lesson to be learned, don't put turbos on cars that are grocery getters.
  #23
Old 03-19-2007, 03:20 AM
planet_keeper's Avatar
planet_keeper planet_keeper is offline
ive been using my vr4 as my daily and for some track use and no major problems so far. that's not to say that i may not be able to do so for much longer until something expensive breaks :P it's kindof turned me into an automotive hypochondriac, i keep thinking i'm hearing broken parts in my engine that aren' t really there because i'm afraid of paying for them, lol.
'93 black vr4, HKS boost controller and gauge, gutted pre-cats, 3sx downpipe, intake, 18" zenetti rims, tein-s springs
  #24
Old 03-19-2007, 09:53 AM
vectorspecialist vectorspecialist is offline
1st gen specs arae 300hp and aropund 305tq, high 13's to low 14's in 1/4, check the faq, it has them listed for all the different versions and gens.
haha, there's a kid with a 3k sl wants to race my stealth tt, i said not now i dnt have insurance on it(way too expensive, i'm 19). he then calls back and said i'm a bitch and so is my car, i'm to much of a pussy to take a car without insurnace out on the rd. problem is the drag spot is a good 5k from the house. that and it despretly needs its 60k tune up. i hate those attitudes.
but neway, go with a civic or something. hell u can get a mid to late 80's 944 for as little as a first gen 3k, and for equal price of a vr4, u can get a 944 turbo. they r nice cars. the best and closest example of cheap, reliable, and fast.
  #25
Old 03-19-2007, 11:38 AM
Nesryn Nesryn is offline
Send a message via MSN to Nesryn
Doing the free boost mod will put you up to the second gen's 320 hp. It's easy and takes like 5 mins, so there's really no reason someone wtih a first gen wouldn't do this...
  #26
Old 03-19-2007, 12:19 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
no, you misunderstood the adage.
Your car can be 2 of the 3:
Cheap
Reliable
Fast
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
  #27
Old 03-19-2007, 01:36 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Exactly. You cant have all 3.
It can be cheap and fast but unreliable.
It can be fast and reliable but not cheap.
It can be cheap and reliable but not fast.
Old 03-19-2007, 01:43 PM
Linebckr49's Avatar
i was hoping it wouldn't have to be spelled out for him, but i was wrong.
[venik]whatever, you don't know anything, a FWD TT on the track can be fast, reliable AND cheap[/venik]
93 3000GT base
  #29
Old 03-19-2007, 04:21 PM
reminds me of a local kid in an ES Stealth who wanted to race me when I had my 18T's in. I told him I wasn't going to waste my gas. He was a little pissed. Oh well, what does he know, he drives his car primered and hangs out with all the honda boys.
  #30
Old 03-20-2007, 08:57 AM
hah time to turn the tables, i never said that u could have all three, i know wat it means, but the 944 is an example of all three, it's old enuf that it can b cheap, it's fast for it's time(considering it had a 2.5l 4cyl.) and they are one of the more reliable cars, it can and i know of them hitting well above the 200k mark. yes if u add in part costs and all the other goodies, it isnt cheap, but o well it a porsche. i'm not venik or w/e, and it's really pissing me off. if u would for once read wat i write, in full, not glance u'd finally get wat i'm saying, i dnt care if i'm banned for life on this nemore, cause u people need to figure this type of shit out, it's basic reading. example and closest, means that it's not gonna b exactly all three(for u glancers,3). um, and also explain the kid on this very forum, he went out and bought a vr4 for 800 bucks, got a baterie and it runs. that's cheap around $850, we all know they r relativly quick, and typicly reliable. and me, i wouldnt do that simple little mod for extra power, for a few reasons, we all know the stock guage is a p.o.s, therefor i would buy a new one of those. then i would get my all important 60k tune up, which we all know is very important. then maybe i'd consider it, but i wouldn't go to only 320hp, i'd boost it to 14- and get w/e ends up coming out
Closed Thread
