Old 03-20-2007, 10:58 AM
ace91 ace91 is offline
Re: Kawaskaki ZX-RR ´03
my apologies, that'll be the last question since i know that it's off topic.
anyway, i'll be looking forward to see your zx-rr project.
adrian
Old 03-28-2007, 11:55 AM
racer917's Avatar
racer917 racer917 is offline
Thanks for the review Joel. Now I know not to buy one of these. Poor fit and an almost worthless resin blob of en engine. Not for me, thanks.
Old 03-28-2007, 01:45 PM
joelwideqvist joelwideqvist is offline
Resin engine is like you say, a blob. But the fit wasn't that bad at all. It came together fine when glued.
/Joel
Old 03-30-2007, 01:07 AM
Pippin1974's Avatar
Pippin1974 Pippin1974 is offline
Originally Posted by ace91
i see, when does his shop open? cause i can't tell exactly when would he open his shop.
how do you contact him? email?
adrian
I just wait when the shop is open and make the order....
Old 03-30-2007, 01:09 AM
Pippin1974's Avatar
adrian
I have to say that the shop is open right now!!!
Old 04-19-2007, 03:59 AM
slightfan's Avatar
slightfan slightfan is offline
How are you going on this Joel - I need some focus to get started again coming off night shift in couple of weeks and looking at getting some serious kit building going have you added any detail to the lifeless looking engine or just leave as is ? as will be covered by fairing?
Shayne
Old 04-19-2007, 12:20 PM
haha, I always think I will manage that...sometimes I even think I could just paint the entire engine block black as it close to never is visible at all. But then I start making some small adjustments that always seem to grow out of hand. In this particular case that mean that I cut away the but ugly exhaust pipes and will try and make some scratch built ones.
I have had a slow period as there is a lot to do with the house we are building but the resin parts and the front mud guard and the frame/swing arm sections are all cleaned up, puttied and primed. I just got some c/f from Dave at detail and design in scale the other day to go on the lower cowl, front fender and air box. Hope to try out the Lime Green color from Hiroboy in a week or two.
/Joel
Old 04-22-2007, 03:01 PM
ketje's Avatar
ketje ketje is offline
Re: Kawasaki ZX-RR ´03
Tamiya has announced their new kit coming soon, kit nr 14109 Kawasaki ZX-RR . Also will be available a new front fork set nr 12619. Date unknown.
Old 05-18-2007, 07:10 AM
While you guys await the 06 Kawasaki kit from Tamiya I'm striving along with my S27 kit where one of the larger steps are done. I've fitted the cowls together, puttied, sanded and primed, puttied, sanded, primed, leaving me with this for a base to be painted.
Worst part to get smooth was the lower cowl and I didn't quite get the surface to level inside the air intake of the top cowl. Finally I just left it as it was and hopefully that won't be too visible.
Off to some base painting. This is my first attempt on using the Zero Base Paints that can be aquired from Hiroboy.com. I've heard a lot about this paint and was really up to try it. It didn't leave me unsatisfied. I painted the parts at a preassure of approximately 20 psi and giving the parts 6 or 7 mist coats from a distance of 10 cm (4 inches). The paint dries flat and the first part was able to get the next layer as soon as I put the second part down. No need for wet coats as the paint will be clear coated to get its final look.
Here's a few shots:
The Kawasaki Lime green color has a pearl effect wich can be viewed on these pictures where the part is held to the light:
Next I'll clear coat the parts and mask the side cowls off to paint the black section on the under cowl.
Comments are welcome as always!
/Joel
Old 05-18-2007, 08:04 AM
Ole_L Ole_L is offline
Coming along nicely, Joel.
Old 05-18-2007, 08:28 AM
nicely done, joel.
i'm about to complete the repsol bike new generation version soon with just attaching the side, the nose fairings, the fuel tank cover & placing the decals
adrian
Old 05-18-2007, 09:18 AM
ketje's Avatar
Hey Joel,
love that colour. This is something different then other bikes.
Waiting for the result.
Old 05-18-2007, 10:05 AM
Tried out the 2K clear from Zero just now. This is a true joy to work with. Brought out the shine ocf the lime green beautifully. I'll show you pictures as soon as possible.
/Joel
Old 05-18-2007, 11:03 AM
sportracer02's Avatar
Hi,
great job on the fairing regarding the parts as they came out of the kit-box.
That green looks cool even without clear (last foto)
Micha
Old 05-18-2007, 04:15 PM
robrex's Avatar
robrex robrex is offline
Joel,
The cowling and paint look great! I'm looking forward to seeing the clear coated body. What paint code was it from Zero? was it just the base Candy Lime?
Rob
