Old 03-13-2007, 03:13 PM
geronimo77 geronimo77 is offline
AutoWeek Magazine Vendor
Send a message via MSN to geronimo77 Send a message via Skype™ to geronimo77
Re: Yamaha YZR-M1 '05 Test bike
Some progress:
Old 03-14-2007, 04:33 AM
joelwideqvist joelwideqvist is offline
Can I call you when it's time to put the wall paper up in my new house?! This is astonishing. So, so great. Top cowl is just wow.
/Joel
Old 03-14-2007, 02:34 PM
The Sheene Machine's Avatar
The Sheene Machine The Sheene Machine is offline
Some of the best carbon work I've ever seen. Stunning stuff. Is there any sort of clear over the carbon decal??
Paul
On the bench;
2003 LV Rossi Honda RC211V
Old 03-14-2007, 02:56 PM
ketje's Avatar
ketje ketje is offline
Looks awsome. Keep up the good work.
By the way, did you paint the parts black first?
Old 03-14-2007, 03:08 PM
Thanks
Yes before the logo decals i applied one coat of MrHobby clear.
Yes one coat of Tamiya TS-14
Old 03-23-2007, 02:16 PM
Some more progress:
Old 03-24-2007, 11:39 AM
I've not been using this smily very often but here it comes...
For me this is so unbelievable. How you manage to make that decal conform to all of those irregular curves on the seat cowl is hard to figure. When pinning down one end you have to grab that side to get the other one to conform. I don't get why the very fragile decal doesn't rip from the handling. On top of that you seem to lay down the team markings with the same attention. Truly great.
/Joel
Old 03-24-2007, 02:35 PM
/Joel
Thanks Joel,
It is a pity that my english is not so perfect that i could describe how i do it. But basicaly what is important to use a lot of softer. And while conforming one part of the decal do not allow to dry out the other end.
It takes around an hour or two (depending on the shape) to apply CF to one part.
Also what i experienced that it is better use wet finger than any kind of flat brush.
Before logos i spray one coat of clear to get smoother surface.
hope this helps
Old 03-25-2007, 09:32 AM
Ole_L Ole_L is offline
Absolutely stunning work... looking forward to seeing more.
Old 04-02-2007, 09:48 AM
SkylineFan's Avatar
SkylineFan SkylineFan is offline
This is spectacular... I Have the kit, and modelers carbon.. but you beat me to it!!! beautiful work sir!!
DaveT
Old 04-02-2007, 04:40 PM
just a little update:
engine block is installed, front suspention and wheel is assembled.
Now i work on the handle bar. i was hesitating to cut out the end of the brake but i think the result is quite good
I used p/e disk brake first time but i think the result is very impressive. i hardly belive that such metal effect can be reached with any kind of paint.
Old 04-02-2007, 05:22 PM
SpoonMan Dos's Avatar
SpoonMan Dos SpoonMan Dos is offline
Very good detailing!
To Be Like Water
Old 04-03-2007, 01:19 AM
Perfect job on the brake lever! What did you use to cover the brake fluid container? Looks spot on. Brake discs are awesome and I love details like the oil plug clip and the throttle fittings!
/Joel
Old 04-03-2007, 12:36 PM
/Joel
Thanks
i used mouse pad for the brake fluid container as usually. Today i will try to finish the handle bar section
Old 04-04-2007, 11:16 PM
willster127's Avatar
willster127 willster127 is offline
UNBELIEVABLE, Nothing else to say!
The Willster....
