Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-12-2007, 07:40 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Fuel Cut
Yes but if you are leaking enough air it will mess up your Air/Fuel ratio. It just depends on how bad of a leak it is.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 02-12-2007, 11:45 PM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
Re: Fuel Cut
How would adding an exhaust cause a leak because there were absolutely no problems before the exhaust. I know it can speed up spool time and maybe add a little to the PSi but i didnt think it would mess with either of those things to cause a A/F mixup
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 02-13-2007, 12:12 AM
steviek's Avatar
steviek steviek is offline
Re: Fuel Cut
New record a triple post.
Adding an exhaust means more air can flow. More air needs more fuel. Causing your injectors to be maxed out.
Also just cause your boost gauge is reading 11.5 doesn't necessarily mean thats what your boosting it could be wrong; it could have a leak in the vacuum hose or simply not be properly calibrated/lost calibration.
I agree that 11.5 on the 16g shouldn't be too much, but the fact of the matter is its happening. It could be a clogged fuel filter for all I know.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-13-2007, 12:20 AM
Re: Fuel Cut
actually i still have the stock boost gauge in my current one is broken and i was going to get it fixed with the next paycheck but it looks like im gonna be buying a whole bunch of other things. running 1gen fuel injectors would still need a tuning device right? or could the stock ecu handle that cuz im really in no position drop 500 bucks for injectors and a tuning computer. So a boost leak test, fuel filter check, fuel injector cleaner? and continue from there becasue those are all cheaper options any other precationary/cheap checks i should perform.
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-13-2007, 12:21 AM
steviek's Avatar
Re: Fuel Cut
Hold on then how do you know your running 11.5 psi?
stock boost gauge tells you nothing.
Also 450's in 2g i don't know what you think they got in 1g's
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-13-2007, 12:22 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Fuel Cut
If you don't have a boost gauge, how do you know that you're running 11.5 psi? Get a boost gauge, a clean fuel filter, and do a boost leak test.
95 Talon TSI AWD
97 Eclipse GST
Old 02-13-2007, 12:23 AM
Re: Fuel Cut
thats where it was set when i got it and i havent touched the MBC since then i got it from DragonofBC. thats where ill start then
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-13-2007, 12:28 AM
steviek's Avatar
Re: Fuel Cut
well just turn your boost controller down a few turns and that should keep you safe. And then at least you can boost it a bit.
also you should definitely check out the upgrade path on dsmtuners.com
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-13-2007, 12:32 AM
Re: Fuel Cut
I have. in fact i have it bookmarked it just that ive had some expensive ass speeding tickets and other car problems that had kept me in debt until now basically. thank god im gonna have some birthday money coming in soon so hopefully i get everything back the way it should be
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-13-2007, 12:44 AM
steviek's Avatar
Re: Fuel Cut
its won't be long.. or hard to do no worries
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-13-2007, 07:29 PM
Re: Fuel Cut
I cant do a MAF hack becasue i dont have fuel management but what about a chip i got this site from DSMtuners
http://www.dsmchips.com/2g.html
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-13-2007, 10:32 PM
Re: Fuel Cut
It may work, but why don't you just upgrade the right way? You'll get the chip, then upgrade the rest of your system, and won't need the chip anymore. Waste of money IMO.
95 Talon TSI AWD
97 Eclipse GST
Old 02-13-2007, 11:56 PM
Re: Fuel Cut
ah ha but i wont have the money for the proper upgrades for another 2 months and for me, thats way too long to even have the possibility of doing serious damage to the engine. plus the chip seems like it has some things that could benefit future upgrades too. I would really rather just skip safc too and go to dsmlink but thats even more expensive. I was going to stop with the exhaust and save up for injectors FMIC and DSMlink and put them in before college.
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-14-2007, 12:39 AM
Re: Fuel Cut
What about gen 2 GMmaf translator?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-14-2007, 02:21 AM
Re: Fuel Cut
Why don't you just turn down the boost a little bit and run it safely until you can upgrade. That chip may work for now, but I'm pretty sure once you get link you'll throw that thing in the garbage, therefore deeming it an unnecessary upgrade.
95 Talon TSI AWD
97 Eclipse GST
