Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 02-02-2007, 01:09 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Transmission issue
Fuck it....My server froze when I posted it, and tried to refresh the page 3 times....I guess it reposted it everytime it tried to refresh.....fixed it
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-30-2008, 09:38 PM
pingui15 pingui15 is offline
Exclamation Re: Transmission issue
Can any one help me to locate where i can add more transmission fluid to my Eclipse gt 2001 5 speed and also when do i know if its full?
Thanks
Old 01-31-2008, 12:32 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
please don't put new questions in old threads
you can't check it. there is a fill plug on the top or the side of the transmission. if it is on the side, it is full when it starts coming back out. if not, then check later on.
second, manual transmissions don't have a dipstick, so you have to wing it.
if a manual transmission isn't leaking, then you do not need fluid. you really should be ok as long as you know it isn't leaking and you change the fluid completely every 30k miles.
lastly, the manual transmissions on the v6's take an even 3 quarts. i recommend BG synchroshift or pennzoil synchromesh (the only pennzoil i actually recommend anyone use). otherwise it's just 80-90 or straight 90 gearl lube. no biggie.
Don't act like you don't love it.
503/2000
Old 10-02-2009, 10:21 AM
RikochetRT RikochetRT is offline
I saw someone said they changed their transmission filter. I have a 02 dodge stratus coupe RT 3.0 L (yeah same as the eclipse GT), and i have seen conflicting things online about changing the filter. Can someone please email me and tell me more about it? I'd very much appreciate it.
