| Members Projects Discussion of the AF 2G DSM Project Car |
#16
Re: NOFX Rebuild Project (56K Warning)
I want some too. You should figure out some prices for us so I know how much to spend on a new deck for the Monte.
#17
Stainless line is skeet-skeet, but expensive. We got lucky once and found a whole bunch of brand new stainless line beside the road. It had flew out of the back of someone's truck or something. So we stopped and picked it up. It was enough to do the whole fuel system on my buddy's Nova.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
#18
So almost everything is complete. I am just waiting on a boot for 1 of the Axles to come in on thursday. I might be starting it up tomarrow and just let it run for a few minutes for the initial break in, and also to make sure nothing is leaking. All I got to say about putting everything back in is...Fuck the wire harness, That thing is ugly as all hell. I wish I had the time to go through and redo the whole thing and hide a lot of those wires. Oh well once I get another daily driver that will be something I can go back and do. I have a new custom catch can that is used on massive air compressors to catch oil and water out of the air. I am going test it and see how it goes. I will post pictures of it on here tomarrow. Man I am getting excited to start this thing up. It seems like forever since I have driven my car. I dont know how a lot of you guys have gone so long.
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
#19
Very nice, your bay is very clean. Your progress makes me want to just fuckin get mine done!
If you sell off some of that SS line, I would like some too. Let me know if you can/will. |
#20
Alright...UPDATE TIME...
I got the car started up this past thursday. It ran like a champ, Until I had no power. It took me a little while to figure it out but we figured out that the alternator was bad. So I went and picked one up on friday and got it installed. The car runs fantastic. It sounds better than I imagined, and the tranny shifts much smoother than I thought it would while it breaks in. So here are some more pictures for all of you guys to enjoy. First here are a couple pictures of my new little catch can ![]() ![]() Here is a pic of the catch can installed in the car ![]() Here is a pic of the engine bay after everything was installed ![]() Here is my friend Danny in front of the car. I owe this guy a ton. He pretty much built the entire car while I sat back and watched and learned. I did learn a ton though and feel confident I could do most of it next time. ![]() Then here I am in front of the car ![]() So after the start up there were just a couple leaks here and there that just needed some tightening. I am having a problem though. After the car has warmed up, when I push in the clutch my RPM's drop and so if I am at an idle then the car dies. I am pretty stumped on it right now. Any suggestions would be greatly appreciated.
#21
Have you correctly adjusted the idle?
#22
Yeah it idles fine at around 600-700 rpms...and that is where it idled at before I did all this.
#23
bring the idle up to about 850 rpm and see what happens that seems a little low. so when the FMIC being installed just to add to the sexiness
![]() 96 GS - 5 Speed-Sold 1998 Ford F-150 XLT 4X4 |
#24
So when you push in the clutch pedal the car kills, but only when it's idling? Am I getting that right?
#25
he says rpms drop. and at idle there so low it cuts off. but i think 600-700 is to low of an idle anyways. i couldnt tell you why idle drop when you push in the clutch, mabey same reason idle rises when turning the wheel??? lol
#26
In simple terms, idle rises when turning the wheel because when you turn the wheel, you put more of a load on the power steering pump, which puts more of a load on the motor through the accessory belt (nt cars) and the engine has to compensate for that load by increasing the rpms.
#27
Yes the car dies when I push in the clutch because the rpms drop for some reason. I noticed today that it died a couple times just coming down from a higher rpm. I was at like 5k and then I let off and the rpms dropped pretty fast and then it dropped right past where it was supposed to idle and then died. Sometimes I can catch it with a quick little rev but not all the time.
#28
Sounds like the exact same thing that happened to me when I blew a hole in my IC pipes.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
#29
So possible like a boost leak or vacuum?
#30
Nice, BTW what those thing in the back ground ? LCD monitor ?
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
