| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs |
Show Printable Version | Email this Page |
#16 | ||
![]() Join Date: Apr 2001
And how would you do this if you are not moving to begin with ... i.e. when you are stuck ? :bonghitte |
#17 | ||
XTerra Guy
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
Keep on smoking....
So what was your question? |
#18 | |
Any professional mud bogger will tell you, driving in mud is all about wheel spin and momentum. A spinning tire keeps them clean and as long as you have forward movement keep them spinning. The less aggressive your tire, the more wheel spin you'll need to keep them clean.
Once you begin to slow down in mud, it's all over. It doesn't matter whether you're in 4hi or 4lo or what gear the tranny is in. If the tires aren't moving you foward, you're not getting out without a tug. Now anyone that has wheeled with me in the mud knows this is the exact opposite of what I do. Unless the mud hole is new to me, I drive into it in 2WD and go until I get stuck or know I'm about to get stuck and then put it in 4WD. As long as my front diff isn't hung up I can usually crawl right out, but sometimes I can't and I get stuck. It adds a little more challenge and fun to it. In my opinion, driving through a mud puddle at 40mph so you can make it through isn't much of a challenge.
Michael Girardo aka Swampwrecker [email protected] www20.brinkster.com/swampwrecker Member - MAXC | NJAX | NJFourWheelers |
#19 | |
XTerra Guy
Keep in mind that mud is different everywhere. In the PNW we tend to get either shallow mud (recent rain has turned the ground slick), or deep pools of dirty water that have a slick bottom. In the first case speed will just send your rear end into a nearby tree and you'll get nowhere. Factor in that our mud is usually on the side of a mountain and you'll realise that often times control is more important. In the second case it's up to the driver to determine what he's getting into (a long standing mud bog, or recent runoff) to decide if speed or traction is better.
Now not having driven in the mud back east or down south I have heard it tends to be much thicker and has more suction like properties. Then speed and momentum are your friend. Which is why I mentioned both techniques. Offroading in your area is not the same everywhere. |
#20 | ||
I sure will
#21 | ||
XTerra Guy
Re: I sure will
I guess it would be more helpful if I just posted "Duh, you're STUCK. Get a tow strap out." |
#22 | ||
Re: I sure will
Hey Schlud, are we finally going to meet you on the 20th of Oct??? Claus |
#23 | |
Schlud is right, mud is VERY different depending on where you are at. If you want some of the nastiest, stickiest mud, shoot for the clay found in GA and TN. Here in Florida we have what we call gumbo mud. It sucks you down like black hole. The bad thing about mud is that most of the time lockers mean little and it can vary for what type of vehicle can run it. Sometimes the short wheel base trucks have an advantage, others the short wheel base trucks get buried and the long wheel bases make it. You just never know. But in all cases, hp is what makes the tires spin. As long as the truck is moving and the tires are spinning, you will do as good as anyone else. Once forward motion is stopped, you are in trouble. I have seen some cases where trucks have backed out. But then I have also seen others where trying to back out only gets you stuck worse.
Running the mud is just a matter of choice. If you hit it slow and it is deep, odds are you will wind up stuck. If you hit it fast and there is water in it, odds are you will experience hydrolock like one of the Jeeps in an outing did (he was running dual lockers). You just have to fly by the seat of your pants and determine your modus operandi on a hole-by-hole basis. |
#24 | |
Really STUCK in thick gumbo mud. :smoker2:
G o l i a t h ~~~ [email protected] ********************************* 33x10.5 BFG KMs on AR-767|ARB Bumper|SR Skid Plates|EOE Sliderz|2" Body Lift|Custom Rear Tire Carrier & Bumper| MAXC ********************************* |
#25 | ||
XTerra Guy
#26 | |
Now THAT'S a doozy! Pine Barrens?
How the heck did you even find yourself in that? Brent |
#27 | |
I had cooling problems for a month after that little mud bath.
#28 | ||
'00 Denim Blue Xterra 3" PM Lift (PM=Poor Man's) 33x12.50x15 Muds Senior Member of ENCXC |
#29 | ||
Looks like you drove straight into a pond on that one. |
#30 | ||
