#16
Re: 96 Dodge Caravan Wont start PLEASE HELP!!
you probably need to do a compression test. !
#17
If you consider lack of power and sluggishness then yes, a compression check might reveal something. However, this started with stalling and no start and now it's running. Can't rule anything out at this point but, it wouldn't be high on my list.
Time to take it to a mechanic. I would have them check for a vacuum leak first since that's potentially the cheapest fix. Yes it's going to cost some bucks but, chances are it's your cheapest route, all things considered. You could always tell them to troubleshoot it only and you could change parts. If you dig your heals in and I hope you don't, here's things to look into: vacuum leak at the intake gasket (should read 17 inches at idle on a gauge) gummed up throttle plate (clean it with spray throttle body cleaner) idle air control valve EGR system Check the fuel pressure (40 psi at idle I THINK???) Fuel pump (check pressure first) Fuel pressure regulator Fuel filter Fuel injectors (listen with a stethoscope for noraml clicking) Check spark plug/wire condition (remove the front three plugs - they could tell you a lot) Compression check Cheers! OBTW - I learned a flashing Service Engine light all the time can indicate a misfire.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan Last edited by RIP; 01-22-2007 at 03:21 AM. |
#18
Follow that list. An EGR valve stuck open can cause misfire & lack of power.
#19
I've been following this due to issues with my own '97, though not this bad. As you know, the 12 is just telling you the battery was disconnected recently. The 43 is the coil thing. Do try going through the list RIP posted, though.
opcorn:
