Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-07-2007, 05:21 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Still with my problem. Moisture?
Originally Posted by david-b
Cool, I will do some research and make sure those relays are the same and give it a try. Do I still need to block off the egr still? Or just by disconnecting the relays will that just stop the flow, like staying closed?
If you disconnect the relays the EGR will just remain closed, or off. I still have my EGR on my car, but I just have the relays disconnected.
You would be suprised how many VAC lines and such are only there for emissions purposes. I have eliminated about 75% of my VAC lines and emissions crap.
1991 GSX 2.3 Stroker
Old 01-07-2007, 05:46 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Trust me, I know...
The only ones I'll have on my car when its all said and done are the few basic ones needed for the turbo system items.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-07-2007, 09:13 PM
defiancy's Avatar
There are only three lines you need on there.
The one from the BOV to the intake manifold, from the intake to the valve cover, and from the FPR to the intake manifold.
Also the ones for your BCS/MBC/EBC
Old 01-07-2007, 10:34 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
I am no 420a expert but on the 4g63t, those relays on the firewall controll the EGR. They run a bunch of vac lines to the EGR among other things. If you disconnect those relays and vac lines there is no EGR code. I speak from experience considering my car has those disconnected and no code. I also spoke to my shop about them and they informed me of the same. I am assuming that there is an equivalent on the 420a as well.
and you say they are on the driveside by the firewall? i looked for them today, not really, but just glanced, and i didnt see any relays, are they lower on the firewall? perhaps under the brake booster?
Old 01-08-2007, 01:17 AM
defiancy's Avatar
I'm not sure on the 2g's. I know that they are there on the 1g's.
It's like a box and all the vac lines and crap that run behind the manifold run to it. If you trace those lines you should see it.
It should still be on the drivers side.
Old 01-08-2007, 08:53 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
when your rpms drop do you hear any noises?!? especially any clunking?!?
I had that problem out of my Stealth... the crank bearings were wearing and it would drop RPMs, usually after letting off out of some high RPM driving, it would clunk (sometimes die) and when it picked up, idle really high for awhile til it regained its composure...
I also had that problem out of my Eclipse ('97 RS), but it wasn't related to bearings... it was my IAT sensor, but the CEL came on and set out that code (IAT current too high)...
And on a different perspective... I drove a Crown Vic (V8 decked out) that had the EGR code come on... I talked with some friends at Advance who said change the PCV... We changed that and cleaned the intake (http://www.partsamerica.com/ProductD...rtnumber=10003 12oz in fuel, 20 in intake[through PCV])
and the car will struggle to stay running and will smoke like a freight train, but gun it till the smoke stops... and that will clean the intake of all the crud it has... and that got rid of the CEL... you may need to clean the spark plugs or do a tuneup after doing this as it will foul them...
Those are just a few different things to think a/b, as they sound semi-sorta related...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 01-08-2007, 10:24 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
There's no clunking coming from the car at all. I've ran that cleaner through the tank before pretty recently, like a month ago or so. Loved that stuff. I'm going to wait for and replace the PCV. Then I'll go from there. I'm really thinking that this is the problem. Logically thinking, with how the car is acting, and exactly what the PCV valve is and does, it kinda makes sense. Is it the 10th yet? lol. We'll see.
I don't think its the IAT. No CELs for that ever. However, I am going to replace that next summer just because anyways.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-08-2007, 10:29 AM
Mikelb's Avatar
still might wanna pull that IAT out and check it... since it's easy to do and not really time consuming... just pull it off the back of the manifold and make sure it's still intact... mine blew completely apart before... then I replaced it... and used carb cleaner and toasted the new one...
2 days to go.... let us know how it turns out (I do believe that PCV is the problem though)
Old 01-10-2007, 01:15 PM
david-b's Avatar
Dave is THAT guy
Today I got the PCV valve and installed it. These damn one don't have the Chysler logo on them, but what ya going to do, right? So anyways, while taking off the old hose going from the valve to the valve cover, it basically disintegrated. Thing cracked and was a pain to get all the pieces off. So I got some heater hose and replaced that too and with new clamps.
Car runs great as of right now. It took a couple miles to see the difference, but when I left off the clutch or pop to neutral, the rpms fall and stay there. I still haven't had the idle surge problem while driving it around also. That seems to have been the problem. I'll be going to work tonight and driving around later so we'll see if there's any problem, however, from looking at it, the PCV valve seems to have been the problem. Yeah!! FINALLY!! Thanks everyone.
75 Monte Carlo
Old 01-10-2007, 01:25 PM
+1 for me! lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-10-2007, 01:39 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Glad to see you finally got it fixed, just hope that it doesn't come back now!
95 Talon TSI AWD
97 Eclipse GST
Old 01-10-2007, 04:18 PM
david-b's Avatar
Dave is THAT guy
Looks like the idle surge is still exsistant, which now takes me to the IAC. It's all good though. Not once when driving to work did the rpms go bouncing around when I let off. They fell down to idle and sat there. Then that once I had the little surges pulling up to the light.
75 Monte Carlo
Old 01-10-2007, 09:53 PM
david-b's Avatar
Dave is THAT guy
So I'm home now, damn I give too many updates. RPMs still fall perfectly, so the PCV was definitly a problem. However, the surging happens all the time. I did play with the fuel maps some today, and I have a higher % at idle then ever before. So that could contribute to it, but I'm thinking not. I'll probably pick up an IAC sometime soon, however, it's damn cold outside and it's oging to snow this weekend
75 Monte Carlo
