Old 12-31-2006, 09:28 AM
ZoomZoomMX-5's Avatar
Re: Scratch x Problem
Originally Posted by freakray
I don't recommend using the Scratch-X on an acrylic.
Why not? I've used it to clean up an old Porsche I painted w/Gunze acrylic and it looks just fine. Also works great on Testors Acryl.
I wouldn't use it on acrylic that's not fully cured. Haven't shot gloss Tamiya in years, so I don't know how it works on that (but it's fine on old '80's Tamiya gloss).
My Fotki Album
Old 12-31-2006, 09:32 AM
freakray freakray is offline
AF Modelrater
Everything I've read about it online says it will attach acrylics.
Of course everyone claims they have been polishing fully cured paint which may not be the case.
AF User Guidelines
Old 12-31-2006, 10:57 AM
I have had problems w/a couple older models painted w/Gunze acrylics, but I think it wasn't due to any particular compound but the fact that even water will damage some of the old acrylics (can't comment on new as I don't use gloss acrylics for bodies) if it's allowed to stay on long enough. Just the moisture in the compound was a problem. Even w/Tamiya fine compound.
The first run of Testors Boyd's acrylics was removed from the market and reformulated into the Acryl line. They were like Gunze acrylics; if you let even one drop of water sit on the finished/polished paint, it would attack it. The only thing you can do w/those models is keep them in a very stable (clean and dry) environment so you handle them as little as possible.
Testors Acryl, when dry, is as tough as any paint I've ever experienced. I just wish I could airbrush the gloss colors as consistently as lacquers or enamels. They're very tricky to get the flow just right. But moisture/compounds will not affect them when dry like other acrylics.
My Fotki Album
Old 12-31-2006, 11:43 AM
speener's Avatar
speener speener is offline
I think to be safe i will get some mediium and fine tamiya compounds. but just out of curiosity, i will also clear coat my test piece painted with acrylics and try scratch x on that.
Old 12-31-2006, 11:49 AM
I have an old tube of Tamiya compound, blue cap, it's the same as what's sold now as "fine". To be really safe you might stick w/fine and finish compounds. They work very, very nicely. I polished out an '06 Mica Silver/clearcoated Corvette ZO6 w/o the need to use any sanding cloths, and it's a mirror shine. Medium compound might be a little coarse, unless you don't have sanding/polishing papers or cloths that when used w/water negate the need for a more aggressive polish on some paints.
My Fotki Album
Old 12-31-2006, 12:22 PM
speener's Avatar
cool thanks for the suggestion
Old 12-31-2006, 12:34 PM
Eric Cole's Avatar
Eric Cole Eric Cole is offline
I've never had much luck with Scratch-X myself, regardless of what kind of paint / clear I use or how long I let it cure. But, having said that, I'm sure it's me and not the Scratch-X because I have certainly seen many cars (by Zoom, Veyron, Cadguy, etc...) finished with Scratch-X with excellent results. I really believe my mistake was in the choice of cloth I used.
Recently, I've only been using the Tamiya polishes and The Treatment Model Wax. ) I find that if I have a decent paint finish to start with I can use Tamiya Course (which will remove minor orange peel / texture), then Fine, then Finish and have a very nice shine. The Treatment Model Wax and a super soft cloth will remove any super fine swirl marks that remain.
The last thing I do, when the model is finished, I use Tamiya's liquid model wax to remove any remaining finger prints, decal adhesive, clean the windows and dust just before it goes in the display case.
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
Old 12-31-2006, 05:09 PM
speener's Avatar
i am using a very soft old t shirt to put this stuff is on is that good?
