Old 12-24-2006, 01:35 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: asap asap asap
Originally Posted by TheSilentChamber
Which one had tachs? Mines an 88 made in japan and it did not have a factory tach, and I havnt no seen one that does.
Factory Tach:
In a very much stock 89 DX CRX.
Old 12-24-2006, 02:03 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: asap asap asap
huh.
-tony-
2000 honda s2000
Old 12-24-2006, 02:26 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: asap asap asap
The weight diff in the 1st gen is b/c of the suspension, engine, and interior parts. the engine is slightly heavier b/c of the MPFI manifold that is 2-Piece, vs the carb'd one.. (debateable)
Then you have the suspension, which I know nothing about, but my STD carb'd model is fine, corners on rails with just urethane bushings and stock suspension (and the front ride height at minimum... so it drives on the corners of the tires.. ) but the suspension barely rolls at high speed cornering.
The 2nd Gen CRX is like 40 lbs between the HF and the Si... rear sway bar and mounts.. and that's all it is. (Unless you have power windows, then it's like 10 more.) You can lose that 40 lbs by taking out parts that are "extra" that you'll never use, such as the tow hooks, and stuff like that. But chances are, you'll add a sway bar to your HF... meaning you just gained that weight and maybe more. So just think about it.
Old 12-24-2006, 06:25 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: asap asap asap
son u have no idea what ur talking about..so go pray aside the pillow of ur bed and ask for common sense
as i pray on the last day of advent and worship of the vigil Mass..today is the last of Christmas Novena
Old 12-24-2006, 07:11 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
Re: asap asap asap
lol...
Old 12-24-2006, 09:11 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: asap asap asap
Originally Posted by dpsayz
hmmph... well if anything i'd blame it on you people at AF and Sport Compact Car mag (jkjk ) because i researched that the 88 had a type of rear steering assist thats good for tuning if you do it right. but w/e im happy for the time being. I'm pretty sure its an hf plus the dude said it has an hf motor ( i hope ).. but of course i'll check the engine code; about to do that in a little. Haha but go ahead and make fun but im jumping into this racing world dammit!! I plan to start out with Solo II in my local area.
You're right about the suspension. The 88 comes with the ITR rear suspension from the factory....just the spring rates are different. The HF also has a front sway bar whereas the DX doesn't.
As for the weight differences, 88 is the lightest year for the 4th generation and every year after that, it gets a bit heavier. HF is the lightest, then the DX, then the Si.
The 88 HF is the lightest 4th gen and the 91 civic si is the heaviest (excluding 4dr's).
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-24-2006, 09:52 PM
Re: asap asap asap
it isnt quite an ITR suspension but u can use 97-01 ITR shocks thats about it..yes its uh true story HF 88's are kickass..which i may sumday get my hands on and do cr-vtec N/A
Old 12-24-2006, 10:02 PM
Re: asap asap asap
i wanna do a hub swap with the crv hubs and some acura calibers, but i like my watanabe rims. so five lug isn't really an option.
-tony-
2000 honda s2000
Old 12-24-2006, 10:10 PM
bambam89lx's Avatar
AF - Advisor
Re: asap asap asap
You're right. The rear shocks are the same though, just different valving. When you shop around for rear shocks for an 88, they'll be listed as 88 civic/crx/ITR.
Old 12-24-2006, 10:29 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: asap asap asap
Accually the ITR uses 88 suspension if you want to be technical about it. Theres also not alot impressive about it, I have an 88 and I like it, but once you lower it a few inches the effect is completely lost. Its achived by having the mounting point for the compensator link mounted high so when the suspension travels up or down (as it would during cornering) it causes it to slightly toe in or out.
As to dropzone... If I mail you a bullet and a gun, will you put two and two together?
Old 12-25-2006, 12:48 AM
Re: asap asap asap
^haha^
-tony-
2000 honda s2000
Old 12-25-2006, 02:50 AM
dpsayz's Avatar
dpsayz dpsayz is offline
Send a message via AIM to dpsayz Send a message via MSN to dpsayz Send a message via Yahoo to dpsayz
Re: asap asap asap
lol i couldnt have agreed with you more.... honestly.. i remember when i used to be like that.. for one.. the power sunroof that the Si comes with adds like 50 or so pounds at the top of the car... making it not very effective in terms of body roll and such.
And thats an awsome piece of information. For a while my dad (who doesn't really know much about imports but has enough common knowledge about automotives.. and it has only been about 24 hours since i've bought the car) thought it was weird that the front of my car would be lowered and not the back; its basically just a poser drag car .. or atleast thats what i thought.. unless by what you are talking about... thats what they intended..... or is this a shot in the dark with this one?
Old 12-25-2006, 04:00 AM
Re: asap asap asap
as for TSC and dpsays u both almost posted somthing i gave 2 shits about! but i do wanna wish u both a Merry Xmas and a better New Yr
Old 12-25-2006, 06:54 AM
Forunn Daberator
Re: asap asap asap
Lowering the front and not the back would be idiotic.
Old 12-25-2006, 01:53 PM
bambam89lx's Avatar
AF - Advisor
Re: asap asap asap
Accually the ITR uses 88 suspension if you want to be technical about it....
Technically, yes.
Also, I could be wrong, (so don't quote me on this) but I believe all the JDM models use the 88 style rear.
The 88 shares everything in common with the JDM base model minus the obvious (jdm body panels, RHD).
The 88 has seatbelt-less doors (as do all jdm models), different door shells w/ longer windows, the different rear suspension, wiring compatibilities...etc. which matches the jdm version.
It's basically a jdm crx imported to the U.S. adapted for american safety standards and emissions control.
