Old 12-20-2006, 11:19 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Need some help
Originally Posted by 89civic_sedan
its the same distributor that ive had sense i got the car.. I just replaced the coil in it.
If its the same one, than what did you mean in your first post when you said you "got a new dizzy?" If you did replace your coil already, I'd say try a new ignitor as already mentioned.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 12-21-2006, 04:39 PM
89civic_sedan 89civic_sedan is offline
Re: Need some help
i got a new one but it didnt fit so i just took the coil out...
Old 12-21-2006, 04:50 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: Need some help
uhhh ok..did it start?
Old 12-21-2006, 07:15 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Need some help
Scrap up some money to get a refurbished distributor from autozone. Try the new distributor and if it doesn't fix your problem just return it.
You also need to trace out your code sixteen injector problem. Make sure the connectors are on and tight. Use a multimeter and test for continuity between pin A1 @ the ecu and the yellow injector wire. Do the same for the second injector (red wire) and pin A5. Also, check the power wires to each injector and the resistor box (top right corner of the engine bay, looks like a mini stereo amplifier) and make sure you're getting 6 ohms on each one and 12v.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
