Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here (for both Pontiac Grand Prix and Oldsmobile Intrigue)
Old 09-21-2009, 01:17 PM
manicmechanix manicmechanix is offline
Re: How to Replace Ignition Switch '97-'03
Well I think if it starts fine the theft light will eventually turn off itself. Without a Tech II you can't really get body codes to pinpoint what the problem is. Do you have another key you can use and see if that does it although I doubt it. Unless you want to disconnect the ignition switch agian and double check the wires and connectors, I'd just run with it and see how it goes.
Old 09-21-2009, 04:26 PM
manglers manglers is offline
That's what we are doing. It got driven to work today, hope it runs ok!!! Thanks for all the help.
Old 10-16-2009, 12:25 PM
tcap1 tcap1 is offline
Excellent instructions for replacing the ignition switch. I have a 99 Grand Prix GT, and with your instructions it went very smoothly, I also happened to know someone who already had the E4 and E5 torx sockets.
I wanted to point out though, that if you have a remote start installed, that it ties into your electronic ignition. This may require you to splice some wires on the ignition harness. Mine was an aftermarket remote start and the wires were soldered onto the ignition wires. It was fairly easy to redo, but it does add some time to the job.
Old 06-28-2010, 03:07 PM
RickRegal RickRegal is offline
Originally Posted by BNaylor View Post
Ignition switch replacement for '97 - '03 Grand Prix
Undo the two screws holding the ignition switch.
Undo the plug at the opposite end of the ignition switch by unscrewing the bolt in the center of the plug and unplugging it. (Use 7mm socket)
Ignition Switch and Harness Assembly
Are the two screws holding the ignition switch female torx screws?
Old 11-14-2010, 08:40 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Also, see this ignition switch procedure located at our Buick Tips & Maintenance forum. May be helpful even for '97-'03 Pontiac Grand Prix owners since the Regal is similar.
Click here
Note: Not applicable for '04 and up Grand Prix since ignition switch is not located in the steering column but dashboard.
Timeslip 08/12/06
AF Community Guidelines
Old 03-16-2012, 10:14 PM
jfenimore46 jfenimore46 is offline
Thanks for these detailed instructions. They really helped me with my 1997 GTP. As others have noted, I did have to go get an E5 Torx socket to remove the four screws inside the steering column cover. I replaced my ignition switch to solve an intermittent problem of no power to part of the fuse block behind the glove box. I had seen this fix in another forum. I would have no power to the Info Panel in the dash, no power to the A/C fan, and the automatic headlights would not work. So far the new switch seems to have corrected the problem.
Old 11-08-2013, 02:45 PM
grandprix2002 grandprix2002 is offline
The new ignition switch I purchased has the slot indexed in the OFF position. However, when removing the old switch, it was indexed in the ON position. So the slot is not aligned with the tab in the steering column. How can I change the position of the slot on the new switch? Can I use a screwdriver to rotate the slot?
Old 12-19-2014, 10:41 PM
victoriamarie victoriamarie is offline
Hello!
My friend and I are changing out the ignition starter switch and the lock cylinder.
We finally got the cylinder out, but the white tubular piece of plastic to the right (facing the ignition) that is connected to the starter switch won't pop out the switch. There's a black tab on the back that we're trying to push but nothing is working.
(We also had to get an E5 in order for this project to work, which was unexpected).
Thanks!
Old 12-21-2014, 06:43 AM
--- nevermind!---
we fixed it but neither the lock cylinder or the start switch fixed the problem.
Old 12-24-2014, 11:24 AM
Tech II Tech II is offline
You never said what your problem was....
Old 03-12-2016, 11:47 PM
tylerlee tylerlee is offline
Exclamation Re: How to Replace Ignition Switch '97-'03
Im replacing the ignition switch in my 1999 biuck regal gs and im having trouble removing the small black connector that has two wires running into it and connects to the white plastic device that if you push up on the metal piece it releases the key any help would be appreciated
