Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 09-28-2001, 05:14 PM
Koojo's Avatar
Koojo Koojo is offline
Send a message via AIM to Koojo
Originally posted by Tireburner
Most factory remotes are 50 feet or less. Holding the remote under your chin will dramatically increase range in most cases. It is not the fillings in your teeth, the remote uses your body as a sort of antenna.
More range can only be accomplished through an aftermarket system.
Hahahaha..are you serious about the under the chin thing? thats pretty cool, i dindt know about that............:smoka:
Old 09-28-2001, 09:08 PM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
Candy=Bad. hehe
You can live in a car, but you can't drive a house!!
MSN: [email protected]
Old 10-01-2001, 10:01 AM
Tireburner's Avatar
Tireburner Tireburner is offline
You could try it. Even extending the antenna wire might work, but keep in mind that the length of the antenna wire is specifically set for the RF frequency that the system operates in. If you miss duplicating it by even 1/4" it can reduce the range.
If you are going to extend the factory antenna measure it from the circuit board to end, then add that EXACT length.
