Old 04-28-2009, 06:14 PM
hendrix3511 hendrix3511 is offline
Re: Starting Problem
I would try replacing the ignition swith, I got one for $40 at a junk yard and it took me a couple of hours to do. They seem to go out on the intrigue a lot so if you get the part pretty cheap, it seems like a good thing to do to eliminate it for sure before you start looking at the computer.
Old 08-22-2009, 07:41 AM
olds409's Avatar
olds409 olds409 is offline
I feel your pain. My 2000 intrigue is doing the same thing.I replaced Pcm, Still working on it.Will keep you posted.
Old 08-25-2009, 10:55 PM
panzer dragoon panzer dragoon is offline
If you turn the ignition switch and the engine does not turn over:
1. Battery/corrosion issues
2. starter/solenoid corrosion issues
3. Ignition switch (common intrigue problem) -if you hear the solenoid click (by turning the key to start) it's not the ignition switch.
Old 01-17-2010, 01:54 PM
o2man o2man is offline
I have a 1999 Intrigue with the 3.8. Some days it fires right up then some days it sounds at start up like it's running on three cylinders, after multiple tries or letting it sit, it will start and run smooth. No codes ever thrown, changed plugs, wires, FPR,PCV, fuel filter, pump relay. It started one and a half days without a hitch and i thought I fixed it, but it started again. Down to fuel pump, coil packs,vaccum lines, ignition switch. The car runs very good once started but I noticed a skip not bad but there is one just holding the throttle @ 4000 rpm. Any suggestions before spending more money and time chasing the tiger ?
Old 01-17-2010, 02:52 PM
-add cps to that list, but I have the LX5. -Usually hard starting with a bad cps, codes can be questionable.
Old 01-18-2010, 12:51 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
I would agree with the CPS (crankshaft position sensor). They are a common failure point, not too hard to replace on the 3.5 either.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 01-20-2010, 06:00 PM
-this is misleading:
For this forum <2010
CPS -camshaft position sensor (I believe this is your fault)
CKP -crankshaft position sensor
-Usually both go out on the 3.5L (LX5) -I have replaced both (2000 Intrigue) and the cps only takes about 10 minutes and $40. CKP is about $80 and 2hrs (remove starter)
>2010
they are now calling the cps a cmp for camshaft position sensor. I would like to drop the cps because it could mean both crank or cam position sensor and just go with cmp.
Old 01-21-2010, 03:38 PM
krivasauto krivasauto is offline
Banned
FOR THE 3.5L (RPO LX5)
CKP:
CMP:
Old 02-08-2010, 02:56 PM
Think the 3.8 would be close to the same ?
Old 02-08-2010, 03:19 PM
maxwedge maxwedge is offline
A990 racer
The cps on the 3800 requires removing the balancer.
Old 02-08-2010, 04:06 PM
The camshaft position sensor on the 3800 is a pain = easier to replace the ckp and cmp (both) on the LX5.
Check this forum for the info or look at the Grand Prix (GP)(3800) info at the top of the forum. There is a very good info on this with pictures.
