Old 12-02-2006, 01:13 PM
acidcrashdburnd's Avatar
acidcrashdburnd acidcrashdburnd is offline
Send a message via AIM to acidcrashdburnd
Re: supercharger
its can be done but it would be better to goto the junkyard and find a SeriesII SC engine w/ the trans pull it out and do an engine swap. i can sell you one out of a 98 gtp with 88k in it for 2300 i was gona do it with my olds 88 but i cant find the time
1993 Olds 88 112k and counting 81 mile a day daily driver.
2005 Grand Prix 47k weekend car.
Old 12-03-2006, 10:14 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: supercharger
Too bad you're in Delaware...
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 12-03-2006, 04:15 PM
Andrewhuffman Andrewhuffman is offline
Re: supercharger
maybe if my enjine ever decides to die, but i think i paid less then for my whole car.
Re: supercharger
it is a vin L
Old 12-03-2006, 06:25 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: supercharger
Originally Posted by Andrewhuffman
it is a vin L
Thanks for the feedback! I have never heard of a VIN "K" 1995! In fact, it is not even listed in the dealer parts manual! I was hoping that there was one on the road, after all this positive feedback that there may be such an animal!
Old 12-03-2006, 06:57 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: supercharger
The proof is in the pudding on the original poster's engine. The VIN ID is what counts in order to give proper advice.
I'm trying to be neutral in this this matter. But you never know Bo. Never say never. From annecdotal information I'm hearing otherwise. GM has done weird things and just because dealer's parts manuals to include AC Delco doesn't mean certain 1995 LeSabres did not have the SII 3800 Vin "K". You'd have to look at the factory production records. Also, I've seen annotations from aftermarket parts suppliers too making an inference. Here is one example from Ken-Co on aftermarket UIM plenum kits.
http://ken-co.com/manifold/default.htm
My brother is a GM SM and he claims he has seen and serviced 1995 LeSabres with a Series II 3800.
However, I'm from Missouri. Seeing would be believing. The saga continues.
opcorn:
Timeslip 08/12/06
AF Community Guidelines
Old 12-03-2006, 07:46 PM
HotZ28's Avatar
AF Moderator Elite
Re: supercharger
At this point, all we have is speculation and hearsay that a VIN “K” 1995 was ever made! I guess now, we must ask if anyone out there has a VIN "K" 1995 Buick LeSabre with a complete VIN #? If we have the VIN #, it could be verified! I would not put much faith in aftermarket supplier fitment details. Your right Bob, “the proof is in the pudding”.
opcorn:
Old 12-03-2006, 09:53 PM
BNaylor's Avatar
Re: supercharger
opcorn:
Hey I am the one from Missouri.....lol. A pic of the engine compartment and VIN number would convince me. All I've ever seen in real life are VIN "L" for 1995. That include a 95 LeSabre I rented back in 1995 at Disneyworld (Orlando, FL).
BTW - What happened to our lawyer friend?
Originally Posted by spinne1
I bought a 95 LeSabre used in 96 (for $16,400) and it had a 3800 SII and I'm certain it was factory installed (I got it with 23,000 miles on it). Side note: I sold it in 1998 for $11,000 to go to law school (which hasn't helped me one bit).
How do I know it had a SII? Before I knew anything about the 3800, I remember looking at the plastic piece under my hood and it said 3800 Series II on it. That memory stuck with me.
Edit Update:
Why does this GM TSB on the UIM plenum problem address 1995 - 1998 Buick LeSabre?
File In Section: 06 - Engine/Propulsion System
Bulletin No.: 01-06-01-007A
Date: July, 2001
TECHNICAL
Subject:
Engine Coolant Consumption or Coolant Leak
(Inspect For Material Degradation/Replace Intake Manifolds)
Models:
1995-1997 Buick Riviera
1995-1998 Buick LeSabre, Park Avenue
1996-1998 Buick Regal
1998 Chevrolet Lumina, Monte Carlo
1995-1996 Oldsmobile Ninety-Eight
1995-1998 Oldsmobile Eighty-Eight
1998 Oldsmobile Intrigue
1995-1998 Pontiac Bonneville
1997-1998 Pontiac Grand Prix
with 3.8L Engine (VIN K - RPO L36)
This bulletin is being revised to correct parts and labor operation usage. Please discard Corporate Bulletin Number 01-06-01-007 (Section 6 - Engine/Propulsion System).
Condition
Some owners may comment on excessive engine coolant consumption, or an engine coolant leak near or under the throttle body area of the upper intake manifold.
Cause
Upper intake manifold composite material may degrade around the EGR stove pipe and could result in an internal or external coolant leak.
Correction
1. Follow the upper intake manifold removal instructions found in the Engine Unit Repair Section of the Service Information Manual.
2. Refer to the arrow in the illustration of the upper intake manifold above. Inspect the inner diameter of the EGR passage for signs of material degradation. Degradation will appear as "pitting" of the composite material in the EGR port passage.
3. If degradation of upper intake manifold composite material is found, replace the lower and upper intake manifolds with the following part numbers:
^Lower Intake - 24508923
^Upper Intake - 17113136 (includes necessary upper intake plenum gaskets)
^Lower Intake Gasket - 12537197
4. Follow the lower and upper intake manifold installation instructions found in the Engine Unit Repair Section of the appropriate Service Manual.
5. If degradation is not apparent, skip to Step 7.
6. Verify the repair.
7. If no degradation is found, evaluate the vehicle for other causes of excessive coolant consumption as noted in the Engine Diagnosis Section of the appropriate Service Manual.
Parts Information
Parts are currently available from GMSPO.
Timeslip 08/12/06
Old 12-04-2006, 05:40 PM
HotZ28's Avatar
AF Moderator Elite
Re: supercharger
I am not being devious here, in fact; I would enjoy nothing more than to be able to uncover the existence of a 1995 VIN “K” LeSabre! If I could find one for sale, I would have to buy it, because it would be a classic in the making. I just did a search for all the 1995 LeSabre’s for sale in the in the nation @ AutoTrader.com & found 178 matches. Unfortunately, there were none listed with a VIN “K”. I realize this was a small sampling of the production run, therefore, I will continue to search for this rare commodity. Again, if anyone has one, or can find one for us, please post your findings here with pics and a VIN number. Come on guys, there has to be at least one VIN “K” out there, out of the 165,315 LeSabre’s produced in 1995!
1995 Buick LeSabre Model Year
Production run: Oct. 1994 through Sept. 1995
Total number produced: 165,315
Total no. sold in U.S.: 142,624
Old 12-05-2006, 11:21 PM
Re: supercharger
lol ill take pictures of it so we can all dream plus i kinda got tired of looking for an lss PCM for the SII
