Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-27-2006, 11:26 AM
firesdoom's Avatar
firesdoom firesdoom is offline
Send a message via AIM to firesdoom Send a message via Yahoo to firesdoom
Re: removing o2 sensor
Originally Posted by Blackcrow64
Autozone or Mitsu dealership.
I got mine from a junkyard for $1.
Black 92(6 bolt) Eclipse Auto N/T 2.0
K & N Air Filter, Megan Racing Strut Bars, 2.25 Mandrel Bent Catback, Unorthodox crank pulley, EGR block off plate, No balance shafts, KYB AGX struts and shocks, two piston GSX calipers
1990 AWD Astro Van
Don't mod a car with problems. Don't swap parts without testing them.
Old 11-27-2006, 11:33 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
That works too I guess... If its not all rusted in also. lol
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-27-2006, 11:39 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
02 sensors suck. I've had that problem twice, I simulated narrowband operations with my wideband so didn't have to do it agian. I lost about 20% fuel economy. Im at 260-270 miles to the tank 70% city 30% freeway. The average I was getting with my old o2's were around 330-340miles to the tank.
Even with the 22mm and a 2 foot pipe I striped the o2 sensor. I eventually had to take the o2 housing off with the o2 still inside the housing to get the bitch off..
Why are you taking the front o2 off? Unless you're chaning the exhaust manifold or o2 housing you don't need to touch that o2.
DSM geek
Old 11-27-2006, 03:41 PM
airFS airFS is offline
I'm putting a new o2 housing on. My o2 sensors might be bad anyway if you said 260-270mi per tank is bad....I dont think I've ever gotten more than 250mi on a full tank.
96' Talon tsi AWD
Mods: greddy upper and lower intercooler pipes _ greddy type rs bov _ K&N intake _ 3" turbo back exhaust _ ngk spark plugs & wires _ garrett T-28 turbo _ greddy oil catch tank
Old 11-28-2006, 12:06 PM
firesdoom's Avatar
Smile Re: removing o2 sensor
Whenever you get that little bugger out coat the new one with anti-seize so this will never happen again.
1990 AWD Astro Van
Old 11-28-2006, 07:28 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Man you should be able to get that o2 sensor out. My car spent all of its life up in illinois and virginia before i got it to SC. The exhaust was all rusted out but i was still able to get the sensor out behind the cat by putting the wrench on and kicking it. The one on the o2 housing was a bitch too but i still got it off with just a wrench and some wd40. Even running straight exhaust with no cat my second o2 sensor is hooked in to the exhaust and i havent had a cel from it.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-28-2006, 08:31 PM
Ya, I couldn't believe it wouldn't come off either. I used WD40 and even hit the bolt, with a wrench hanging off of it, with a baseball bat 4 times. Whenever I bought the car it came with some kind of cat-back so I hope the previous owner didn't put something on the bolt. I'm going to try and get it off again soon.
96' Talon tsi AWD
Old 11-29-2006, 07:55 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
i got a cel from running with no cat, and cleared it... keeps coming back... hope i can over-ride it with DSMlink or somthing
Old 11-29-2006, 11:26 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
You should be able to override it with dsmlink.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 11-29-2006, 05:39 PM
2of9 2of9 is offline
dsmlink can over ride the o2 sensor. i learned something new today. what else can elimnate this sensor other than dsmlink...or is dsmlink the only way?
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 11-29-2006, 05:57 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
punch out the cel lightwith a screwdriver or something. clears all cels.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 12-07-2006, 05:40 PM
Well after long await I finally got the exhaust on but I had to take it to a shop which turned out to be more expensive than I thought...$300 w/ icluded a new o2 sensor but my parents paid for half anyway...it sounds so much better than the old cat back that was on the car. It sounds about the same at idle and low rpm, but when you step on it it really sounds good. The only problem is when I got home (about 5min ago) it smelled like something was burning so I popped the hood and a bunch of steam/vapor came out but that may have been b/c it's like 20F here. They also didnt put the heat sheild back on the o2 housing...
96' Talon tsi AWD
Old 12-07-2006, 06:36 PM
Black99GST's Avatar
thats just new metal... its going to smell... also the smoke is probably from some WD-40 or PB-Blaster congrats on getting it apart!
Old 12-07-2006, 07:36 PM
SLoe's Avatar
SLoe SLoe is offline
Yeah, next time, heat the bung with a torch, or run the piss out of the car to heat the exhaust. If that doesn't work heat it and then pour a little ice cold water on the 02 sensor and it should break free.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 12-07-2006, 08:04 PM
Ya, eventhough I never mensioned it I did try that too, but obviously no luck...
96' Talon tsi AWD
