| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#16
Re: Fuel Injector question and information
Exactly, neither the fuel pump nor opti are a fun job to do which is why it pays to cover all basis and determine where the problem lies. Your gauge should come with some basic intruction on how to isolate and determine which of the fuel system components is at fault should there be a unacceptable reading found. If not, you know you can get help here
![]() Also, Formula has touched on a noteworthy point that sometime at idle or low throttle situation, readings will be normal, and only a road test will pin point the dropoff, however, it sounds like your problem exists at idle and should be readily apparent if ti's in the fuel system. |
#17
When I'm driving...lets say at 1200 RPMs...you can hear that clicking noise sometimes in the engine compartment. Then while cranking up it can take a second time just to start it up, or waaay too long of turnovers. Oh, and the blasted Autozone didn't have a fuel pressure gauge. Just great. I'll have to go to another place tomorrow.
1996 Pontiac Trans Am- 85,000 miles Black/Black leather interior, auto trans, BMR rear lower control arms, Trick Flow Air Inlet, Russell brake lines, slotted front rotors, Auburn differential 3.23 gears with bolted alum. girdle. Trying to fix my repairs now. So sad really. But with every replaced part, comes a better part! |
#18
Okay, finally got a pressure gauge that works.
And here is the deal... Pressure when first turning key over: 47 psi But, pressure drops. It does not stay constant. Isn't it suppose to stay at around 41 or so? It just totally drops to zero (0). Pressure when at idle: 41 <-- I think, didn't write it down. Anyway, I kinda figured that if the pressure drops then why not just cycle the pump once, then turn the key back to "off" then just crank it when there is pressure, and this morning it cranked right up. Guess it just means I'm not keeping constant fuel pressure. I'm thinking about buying some new fuel injectors to start with because these "cheapy" ones I think maybe one cause to the problem as they are not solid metal like the stockers. What was the regular stock number for the injectors? 24 lbs/sec? And should I get the Accel Injectors from Summit or get those Ford injectors? Not sure which would be better.
#19
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
#20
Sounds like you fuel pump, go ahead and get the injectors because the onse you have are crap but get the pump done aswell.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering ![]() |
#21
Where is the check valve? Is that just part of the fuel pump? Basically just need to get a new fuel pump then? Yeah, those injectors are garbage too. Stock fuel injectors? What are the numbers?
#22
#23
Stock injectors are 24lbs.
#24
#25
Excellent.
I really appreciate the combined knowledge. I'll let you know how this job goes. Looks like it's just a matter of getting that fuel tank off and I should be good from there. Just have to order the parts now. "Cha-Ching" Autozone wants around $350 for a pump...forget them.
#26
#27
*whew*
Good thing I read this before I bought my Edlebrock pump. I'll check that link out when I get home. Work doesn't like eBay. Go figure.
#28
The only downside is they're noiser, but at least they work. |
#29
I use to run 30lb SVO's and now run 42lb SVO's. If you have a modified engine, most likely you won't be hearing the solenoid clicking over the exhaust tone. Ford does make some damn good injectors though.
#30
Yeah, mine is basically stock. Just the simple bolt-on stuff; K&N, underdrive pulleys, SLP cat back, SLP chip, intake baffles removed, 180 thermo, etc.
The car started running odd on occasion a year ago (I only drive it in the summer months) then this spring it was running really crappy. Diagnosed two bad injectors (ohms way off spec) and one marginal. After much research decided to go with the Bosch (Ford) injectors because they were cheaper and lots of "stuff" flying around about how crappy the OEM Multecs (Rochester?) were. This is in a 91 Z. |
