Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-12-2006, 01:39 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: 96 passport- hole in engine???
Originally Posted by surferfletch
This much coolant will pool between the heads without any drips below the engine. The way it was explained to me on this board was that it just spills over the top at the rear of the engine, which seems plausible...
surferfletch, thanks for the photo.
when you had this leak (up top), were you able to see the pool of coolant when everything was installed ? inotherwords, is it possible to tell just by looking before taking everything apart>?
thanks
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 11-12-2006, 09:22 PM
brianrueb brianrueb is offline
where was the coolant coming from under the car? Did you see that? Did it look like it was coming from behind the tranny? I did not see anything behind the tranny that would be a plug other than that hole, and that is not supposed to be plugged. I just dont know what else could leak from behind the transmission other than that hole.
if you don't know what your doing... buy a CRX. you will feel better in the morning.
88' CRX DX
Si 5 spd conversion
d16z6 swap
15" GS-R wheels
DC exhaust
A'pexi V-AFC
ZC hood (best thing ever)
AEM cold air
14b turbo setup
un-tuned 285whp
96' Passport EX
don't know why, but I got it CHEAP!
Old 11-12-2006, 10:14 PM
surferfletch surferfletch is offline
I had to get a flashlight and really look down in there near the thermostat housing. It's easy to miss if you just glance under the intake.
Let me see if I can find the thread where I first noticed the loss of coolant...
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 11-12-2006, 10:20 PM
http://www.automotiveforums.com/vbul...t=coolant+leak
Here is the original thread...
Old 11-15-2006, 09:05 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
what a deal you got!
I wish I had not gone a week without getting in here this is one of the funnies things ever yes its just a drain hole so that when those coolant pipe o-rings leak the coolant wont stay on top oof the engine I really nee to come across a deal like that
Old 11-15-2006, 09:11 PM
the dealr that worked on this has a real D/A for a tech
how much did you get it for
Old 11-15-2006, 09:12 PM
Then I must have gotten hosed! Is there no plug back there at all???
Old 11-15-2006, 09:16 PM
yes there are core plugs on the back of the block and on the heads but what he is talking about really sounds like the weep hole at the top of the block
Old 11-15-2006, 10:07 PM
Thanks! I can go back to that mechanic then!
Old 11-16-2006, 02:15 AM
I paid $500 for the car and then $680 after tax to have the tranny put back in. There were a bunch of bolts that they had to re-tap that Honda just cut off, and I had to find bolts at a wrecking yard becuase Honda also lost all of those. If anyone on here ever needs ANYTHING for the passports, this place called Covey's in washington does only mazda and isuzu. They had about 20 passport/rodeos and they ship stuff to anywhere. They pulled a motor and tranny just to give me all the bolts. They labeled them and put them all in baggies and I got some new coolant lines and stuff for $60. So total, I am about $1250 for a PERFECT condition passport. Now all I need to do is tear off the intake and fix that leak. You are sure that's just a drain hole for the intake valley? I am pretty sure too, but as you can see, the Honda techs here are STUPID. Thanks for all the help.
88' CRX DX
Si 5 spd conversion
d16z6 swap
15" GS-R wheels
DC exhaust
A'pexi V-AFC
AEM cold air
14b turbo setup
un-tuned 285whp
96' Passport EX
Old 11-16-2006, 02:35 PM
No need to doubt 2eye!
