#16
Re: block numbers
am i right in my thinking,that the only way to tell the 302 from the 350 block is in the bore? beside the casting on the crank.
1965 ss conver chevelle "red 1964 ss impala "red" 1964 bisq. gold 4 doors current 1968 chevelle " all apart at the moment" |
#17
Re: block numbers
Are you saying that the 305 did not exist (in a Chevy) in 1960-66? BTW - The 302, 327, and 350 all have a 4.001" bore. The only way to differentiate is the stroke, or the resultant crank casting number. Since some builders assembled 302s with 2.45" spacer mains (or aftermarket medium journal cranks) even the mains sizes don't always follow suit. If you have a ruler graduated to at least ¼" resolution, you should be able to determine what you have. It is even easier if at least one of the pistons/rods is still installed. A 302 has a 3" stroke, a 327 has a 3¼" stroke, and a 350 has a 3½" stroke (3.48" actually, but your scale probably isn't graduated in hundredths). Besides, true 3.500" stroke cranks are commonly available, but I'm confusing you enough already. |
#18
Re: block numbers
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
#19
Re: block numbers
now you talking , that was a really good explaination for me.
very well put! i thanks you for clearing that up for me. so if i set up a idicator off the block and onto the piston and crank motor i will get exact stoke?
#20
Re: block numbers
a v6 between 1960 and 1966? in a truck?
#21
Re: block numbers
yeah and the 4.3 v-6 that was always in old s-10's is actually a 350 with two cylinders missing, i believe anyways.
also, wouldnt a 302 rev pretty damn high with that short stroke? i have heard stories of 283's revving up to 10000 but i dont buy it unless maybe they had a lot of mods, especially in the valvetrain. |
#22
Re: block numbers
10K may be a little high, but 8-9K is possible with light pistons in a 283.
#23
Re: block numbers
Yup - Couldn't fool silicon212. He picked up on the V-6 out right away. You can usually trip up some people asking about the "305" with that one. That engine family included the 305, 351, 379, 401, 432, and 478 V-6s, plus the 637 V-8, and the 702 V-12.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
#24
Re: block numbers
joe68,
I was reading your following expertise test and found out that my block casting number match your test. I read further and found out I have a 302ci from a 1969 Camaro Z28. Where would I find the 'right front pad' number? I am new to muscle car code identification and just need some help. Mine is a 1968 Impala and was told I have the original 327 :-) Doesnt seem to be the case. ok guys lets test your expertize block cast number 3956618 cast in front of gm is the numbers 19 right front pad v0307hu |
#25
Re: block numbers
This is a pretty good necropost here ... The "right front pad" is actually on the block, directly above the right water pump outlet (on the LEFT when looking at the front of the block head-on, the even numbered side). It's a machined extension of the cylinder deck, where information regarding the block is stamped (usually information pertaining to the assembly factory plus a part of the VIN, usually the last 8 digits of the VIN for a '69 through '80 vehicle). A '68 will have a large journal block, whether it's a 327 or 350. The block identification would be the same on either (as above, usually these were 3970010 - alternatively, just 010 - blocks). To determine whether your engine is a 327 or 350, you could measure the stroke or pull the pan off the block and check the crank casting #. I've given the relevant numbers above. The 327 uses a 3.25" stroke where the 350 uses a 3.48" stroke. A 302 would have a 3" stroke. All would use a 4" bore, and beginning in 1968, a common block.
#26
Re: block numbers
Thanks Silicon for the fast response. In this post thread, a 19 in front of GM then block code 3956618 is from a 1969 Camaro Z28? Here's what I have, without measuring the stroke, can you tell me the engine size?
block cast number 3956618 cast in front of gm is the numbers 19 right front pad v0422pa Again, I am totally new to this engine decoding. I just purchased a 1968 Impala Convertible cloned SS327 and a 1968 Corvette Convertible with a 396 from a 1965 Corvettte. I didn't have a problem decoding the engine from the Vette. Thanks in advance. |
#27
Re: block numbers
See this link. http://www.nastyz28.com/sbchevy/sblock.php
Re: block numbers
Thanks MaxWedge - I looked at the engine block suffix again and it's FA instead of PA. The NastyZ website confirmed it's a 1969 327. Thanks again.
#29
Re: block numbers
sorry guys this was reposted somehow from a long time ago!
can't explain it! but anyway motor was done and in car and running, hope to finish this winter, thanks for all the help
