Old 11-05-2006, 02:22 PM
thurman8her thurman8her is offline
Re: 1991 geo metro engine swap
well guys i pulled the trans last night and the pressure plate has been grinding on the trans. but that flywheel sure seems to be quite a ways from the rear of motor. also i replkaced the rear crank seal and i never seen a spacer.
Old 11-06-2006, 02:36 AM
hey guys, thanks for the help. it was just like davidlang said there was a spacer between the crank and the flywheel. pulled it out and now geo works great. thanks again
Old 11-27-2006, 12:00 AM
Red face Re: 1991 geo metro engine swap
i checked my codes and it says my problem is the iat. what is a iat and where do i find it
thank you
Old 11-29-2006, 12:20 PM
SchlockRod's Avatar
SchlockRod SchlockRod is offline
IAT is intake air temperature.
It is the sensor in the air filter.
Check the connection and the sensor.
Over...
Old 12-02-2006, 10:29 PM
Slockrod u were right about the iat i had lost the wire clip that holds the plug in. thanks now i have one more problem, when i swapped engines i couldnt find the wire to one of the sensors that is located at the front of the motor under the throttle body. anyone know what this sensor is thanks
