Old 10-24-2006, 02:23 AM
KiwiBacon KiwiBacon is offline
Re: backpressure
Originally Posted by UncleBob
This goes back to the basics of an engine. An engine is an air pump. The more efficient the air pump, the more power its capable of. Back pressure reduces air flow, therefore its bad.
Not only does backpressure reduce airlflow, it directly sucks up an engines power in pumping loss.
Pumping loss = pressure * flowrate.
Old 10-24-2006, 09:35 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: backpressure
True, but lets not confuse power (measured in HP) with the original spirit of the question which concerns torque.
Its quite true that more flow equals more hp, but that is not necessarily true with torque. As a general guideline, exhaust velocities of about .35 mach are where things start getting restrictive. So (again, very general ideas here) if a person were to choose an exhaust that sustatained just under .35 mach at WOT at redline, then it would probably be the best torque production you could expect without a significant loss of HP. If you're going for all out HP, go bigger. If you want a quieter more torque-producing exhaust, choose something a little smaller that coincides with the torque peak.
Dragging people kicking and screaming into the enlightenment.
Old 10-25-2006, 12:24 AM
Re: backpressure
Torque and power are different ways to measure the same thing (engine output).
Anything which requires power (like pumping against exhaust backpressure) also requires torque.
So where the pumping loss is: Power = pressure * flowrate.
The torque loss is: Torque = (pressure*flowrate)/rotating speed.
Where the crossover lies between torque lost (to creating high speed exhaust pulses) and torque gained (through scavenging) is obviously the subject of much R&D engineering.
Old 10-25-2006, 12:33 AM
UncleBob UncleBob is offline
AF -Advisor
Re: backpressure
its a definition thing.
When most people say "that engine is torquie" what they really mean is, that engine produces good HP at low RPM's.
Low back pressure does not necessitate a "non-torquie" engine. Quite the contrary. A low back pressure system with properly sized exhaust/ports will greatly enhance the "torquie"ness of an engine....it very well could cause suffering in higher RPM's of course
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 10-25-2006, 09:33 PM
cody_e cody_e is offline
Send a message via AIM to cody_e Send a message via MSN to cody_e Send a message via Yahoo to cody_e
Re: backpressure
Somebody told me if you didn't have any backpressure or little backpressure you'd burn the valves.
Old 10-25-2006, 09:35 PM
AF -Advisor
Re: backpressure
that is only true if you have extremely short exhaust. As in, exhaust that is a total length of 6 inches.
Back pressure isn't what holds the heat, its the metal that the exhaust is made of. If its of sufficient length (and it doesn't have to be very long, really) then it will prevent the exhaust valves from cooling off too quickly.
Old 10-26-2006, 03:23 AM
curtis73's Avatar
Re: backpressure
Well... yes and no. Mostly the "no" part.
Engines produce torque. HP is a derivative of that torque. HP=TQxRPM/5250, so HP is completely dependent on torque production.
Consider this formula....
MKA=AGE x SEX
Where, MKA = Mary Kate and Ashley
AGE = 18
and SEX = when we can bang them legally.
MKA is producing torque, but they aren't making HP until age 18, so we can't make sex with them until a certain RPM... wait...... no, I mean sex with torque...
crap, I messed it up again.
Old 10-26-2006, 03:26 AM
curtis73's Avatar
Re: backpressure
Partially an old wive's tale. If you run an engine with very little exhaust (like open headers or no manifolds at all) you run the risk of cracking valves. After running an engine and getting the valves screaming hot, the lack of exhaust means ambient air is exposed to the valves. Screaming hot valves plus ambient air can mean cracked valves.
Old 10-26-2006, 06:27 PM
psychopathicdude's Avatar
psychopathicdude psychopathicdude is offline
Cool Re: backpressure
Mostly the "no" part....
Nice use of (MK+A)(O). It's going into my Calculus notes.
This Space Intentionally Left Blank
Old 10-26-2006, 06:29 PM
Re: backpressure
Oh man this is funnny: http://www.noiseoff.org/exhaust.shtml
Old 10-26-2006, 07:16 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: backpressure
since bikes are you area, maybe you can help answer this.
i read that bikers that fit open race pipes to their bikes often find that they desroy valves due to such low back pressure, so the exhaust isn't any shorter, but it is far more free-flowing. so what is it about the more free-flowing exhaust that destroys the valves?
Seatbelts Saved My Life
Old 10-26-2006, 07:28 PM
Steel's Avatar
Steel Steel is offline
Re: backpressure
Ah...no. Torque is a measure of work, Power is a measure of work over time. Engines can produce massive torque while not making much power, and vice versa, they can produce massive power without much torque. Long stroke diesel vs formula 1 engine as examples.
Remember though, that power is just a mathematical toy, derived from torque. Torque is the only thing an engine actually produces.
Old 10-27-2006, 01:10 AM
AF -Advisor
Re: backpressure
I've yet to see such a situation, so I say BS
Old 10-27-2006, 01:11 AM
AF -Advisor
Re: backpressure
torque is a really handy measurement in a plane of existance without time.
Since we don't exist in such a plane.....
Old 10-27-2006, 01:49 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: backpressure
Is that a royal "we"?
Because I have blue telephone box in the garage that can get around a few time related issues.
