#16
Re: Engine size
umm... just so the dude that started this thread knows, ALL chevy smallblocks are THE SAME SIZE on the outside (actually, i bet chevy made some taller deck versions, but for the most part their the same)
the only difference is power output and bigger displacements sound better. one thing you might need to look into is some bigger rear tires (wider not necessarily taller) and definately a posi rearend if you dont already have one. if you run an open rearend with stock size tires and a turbo350 or 400 transmission, a 400c.i. or even a 350 when souped up will burn out all the way up to 90 miles an hour or so. a big block possibly could do it with posi even though i doubt it. |
#17
Re: Engine size
i have a 400 sbc in my third gen. well actually its out now and in the machine shop being hot tanked and inspected and bored and then im gonna rebuild it all bad ass. but anyway it just bolts right back in as if your keeping the old 350 or 305. what ever you are starting out with. easy swap and if you build that thing up they are torque monsters
87 firebird formula ws6 (currently has a old 78 305 with the following upgrades, including lots of miles and stock heads and internals....oops) crane cam cam specs performance valve springs and retainers, flowtech headers, 255 lph fuel pump, holley 600cfm carb, weiand single plane manifold, a healty diet. 14.90 1/4 mile....just wait for the 406 to be finished MY VIDEOS MY PICTURES -Tom |
#18
Re: Engine size
very true... im building a smaller 383(though still pretty big by smallblock standards), that should be able to muster somewhere around 500lb/ft of torque. if you build them right, a 350 can easily make a streetable 400+lb/ft and well over 400 horses also. its all in the combo
#19
Re: Engine size
by the way, is it possible to fit a big block into the late 80's early 90's style IROC camaros? i have never seen one with a big block in it before and maybe they dont fit or something i dunno
#20
Re: Engine size
a big block such as 454 is very close dimension wise to a SBC. So it should not be all that difficult to get one under the hood.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
#21
Re: Engine size
I've seen one with a 502 nessled in there, was like a really fine female with a low belt line and a lacy g-string poking out
#22
Re: Engine size
i want to see someone drop that 572 in there
#23
Re: Engine size
