#16
Re: 2000 Avalon Check Engine Light..
Hi,
The ECM code is P0440. Please let me know how to fix it. Thanks Guna |
#17
Possible Problems
Fuel tank cap incorrectly installed - loose <= Most common Fuel tank cap cracked or damaged (Use Toyota part only) Bad vapor pressure sensor/circuit Vacuum hose cracked, holed, blocked, damaged or disconnected Hose or tube cracked, holed, damaged, or loose Fuel tank/filler neck cracked, holed, or damaged Charcoal canister cracked, holed, or damaged (collision) In above description, check hoses between vapor pressure sensor and VSV for vapor pressure sensor and charcoal canister. Also, check the hose between charcoal canister and fuel tank.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
