Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-17-2006, 12:19 PM
capriceowns capriceowns is offline
Re: F40H.D. vs. F41
Are front springs something I could do in my driveway or is it better left to be done by a shop? my front shocks and springs are gone, everytime i hit a moderate bump the front bounces like 5 or 6 times before settling down, lol.
I might do impala ss springs and 9c1 shocks front and rear. I can order the shocks at wholesale from my work
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Old 10-17-2006, 02:46 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: F40H.D. vs. F41
You can do the front springs yourself provided that a) you have a lot of patience, b) you have access to a set of spring compressors, and c) you have lots and lots of patience.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-17-2006, 04:20 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Re: F40H.D. vs. F41
I've rebuilt/replaced every single part of a car over the past twenty-five years, and there are two things that just aren't worth doing:
exhaust and ...
front SPRINGS
That was on a 77 Cadillac. Since then I've found out it would have cost about the same as I paid for the springs alone to have the sping shop supply & install them. A few years ago I had my 73 Buick Centurion done all around for CDN$350.00 out the door.
Rear springs are a piece of cake though. I replaced mine a few months ago with moog variable rate springs, and just took them out again on Sunday afternoon to install Monroe Sensatrac coil over shocks. Regular shocks are easy with the springs in, but coil overs really need to have the spring removed as you don't have straight access to the nut/bolts at the top as with the standard shocks.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 10-24-2006, 03:11 AM
beat88ls's Avatar
beat88ls beat88ls is offline
Re: F40H.D. vs. F41
Originally Posted by silicon212
I believe it was also on some later model Broughams, 1986 and newer.
yeah, my 88 LS had a rear sway bar... wish i still had that car
1997 Jeep Grand Cherokee Laredo 4.0L
2004 Jeep Grand Cherokee Laredo 4.0L
1983 Caprice Classic 5.0L
Old 01-24-2013, 04:32 PM
Maynard37 Maynard37 is offline
Re: F40H.D. vs. F41
Why did Chevrolet list a "GU4" as well as a "G92"? Both option codes refer to the rear axle / differential: the former is for "3.08", and the later is for "performance axle". This is as clear as a bowl of mud.
Old 01-24-2013, 04:43 PM
Re: F40H.D. vs. F41
My '89 Caprice w/ a F41 suspension option, lists a "GU4" as well as a
"G92" on the "options sticker" inside the trunk lid. Since both of
those codes refer to the differential ratio, it seems like a duplication.
Anyway, it's rather unclear. Can anyone elucidate?
BTW, I tried Edmunds.com to learn more about my car. I entered
its VIN, and it came back claiming that is was an LS Brougham.
It is not----it's just a plain (though loaded) Brougham. So, in
other words, one cannot always believe what they're told,
regardless of the type of source of the info.
Old 01-24-2013, 09:46 PM
silicon212's Avatar
Confoundingly Lucid
Re: F40H.D. vs. F41
Nice 6.25 year old necropost!
The G92 might be a redundant code or an enforcement of the GU4 code.
Similar to transmission codes MX0 and MD8, which will often appear together, where MX0 is Merchandised, auto with OD, and MD8 is THM700R4/4L60.
Old 03-25-2014, 10:07 PM
renaldorae renaldorae is offline
Re: F40H.D. vs. F41
G92 is the performance axle and GU4 is the axle ratio 3.08 f41 s the supension code and MW9 is for the 200 R4 tansmission. The Code for a Brougham LS is B6N 9C1 is the code for the police car only has nothing to do with a brougham 9C1 is a base model and will have a BL in the vin vs the brougham will have a BU in the vin and if 9C1 has a 4.3 v6 it have a vin code Z gas or fuel injection and if its the 7 code thats a 350 and the E is a 305 TBI. H code caprices are a 305 with a carb and thats 88 or less 89-90 are E codes only with the exception of 9C1. Also a 9C1 is the only car you could get a 5.7 l code 7 engine from the factory. I had an 84 caprice 87 classic and i currently own an 89 Brougham LS that i have had since 2000 for the most part all chassis parts from 1971 -1996 are generally the same shocks springs and arms ball joints and links. monroe coil overs are the best shock for a caprice in my opinon and the lower springs add to stibility and cornering quite a bit especially if you have the F41 package. one last thing the LS top of the line distintion was only from 87-90 all other LS designations are base model cars and you know you have the LS if you have the quarter top full vinyl tops are broughams only.
Old 03-26-2014, 11:06 AM
silicon212's Avatar
Confoundingly Lucid
Re: F40H.D. vs. F41
A few clarifications of the above post:
VIN code E (8th digit) is L03 305 (TBI), code 7 is L05 350 (TBI), code H is LG4 305 (Q-jet) and code 6 is LM1 350 (also Q-jet).
Also, the platform ran from 1977-1996, not 1971.
Old 03-29-2019, 11:46 PM
Jesse Vincent Jesse Vincent is offline
Re: F40 H.D. vs. F41
To GreyGoose006, as re: your post a while back:
No, 9C1 does NOT mean F41. 9C1 is a police car 'package', which likely includes the F40 heavy-duty suspension option --- which is DIFFERENT from the F41 sport suspension option... though there may be some common items for each of those two optional suspension packages.
This is a common misconception, unfortunately.
To renaldorae, I much prefer Delco stock, or Gabriel shocks over any Monroe.
Old 04-01-2019, 04:39 PM
silicon212's Avatar
Confoundingly Lucid
I think he was actually asking if the F41 came as a part of the 9C1 package, which is affirmative. I don't think he actually thought that if F41 was present, that it was automatically a 9C1.
